Page 22 of 29 FirstFirst ... 121314151617181920212223242526272829 LastLast
Results 211 to 220 of 281
Thread: Vehicle Maintenance Coming soon
  1. #211
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    Quote Originally Posted by tbird2340
    This looks very promising! Maybe add an export to csv function? I will wait until it's skinnable so I can match it up with the look of my frontend..
    Great little program!
    Yeah, so that you can print your records if you needed to.
    Final Touches
    Car: 2002 Mitsubishi Magna EI
    CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
    Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
  2. #212
    Raw Wave lostreception's Avatar
    NY
    ok so heres whats up im making some progress in integrating the flash with vb
    my skin codes etc will be similar to roadrunner
    for example
    home,0,65,185,65,0,0,0,14,"Arial",Home,,
    gas ,0,130,180,65,0,255,0,19,"Arial",Gas Fill,"center"
    events,0,200,180,65,0,0,0,14,"Arial","Calender",
    but im wondering if im going about this in the wrong way maybe i should just write some supplemental code for rr and maybe we can incorporate it with RR?
    just a thought
    this would of course not then work with CF and the other Front ends
    any suggestions from the proggramming end
    i want it to run as fast as possible and i currently use rr
    let me know
    -Lost
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  3. #213
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Download the RR source (if you haven't already) and look at the plugin structure.
    You can use that to build a plugin for RR that also can run on it's own or with other frontends.
  4. #214
    NY
    Quote Originally Posted by Enforcer
    Doh! thanx i overlooked that folder now ill be able to finish this much faster
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  5. #215
    Sharjah, Emirates
    good luck
    Final Touches
  6. #216
    Feb 2006
    Hingham, MA
    Will this work with touchscreen displays. This program looks great! I am downloading it now to try it out. Also any word on being able to print or print reports out of this app? That would be great.
  7. #217
    Feb 2006
    Hingham, MA
    Ok so I just tried out the software. Seem like it is going to be very nice once it's completed.
    Findings:
    Under Setup. When adjusting the colors they will not save if you just choose a color and hit "Save". Right now you have to hit "Preview" & then "Save" for the changes to appear.
    If you go to any button on the Main Menu.. then click "Back" or "Cancel" to go back to the Main Menu and then go into Setup; the "Colorize Header Bar" / "Back" button locks up and you can only get out of it by closing app or by choosing a color, clicking preview, and clicking save.
    Suggestions:
    Gasoline: - Allow a date to be selected for "Date Last Filled" (in case you don't enter the data the day you filled up)
    Maintenance / Oil Change - Set date is not working. Also I change my mileage to show 43,320 (Oil Change should be due now) No warnings or reminders popped up. Did I enter something wrong or is this feature not working fully yet?
    OSKeyboard - Anyway of added a full QWERTY for entering alpha data?
    Just my .02 worth I like the way this app is going though. Keep up the good work.
  8. #218
    NY
    Quote Originally Posted by gold007eye
    Findings:
    Suggestions:
    thanks for the feedback Maintenence is not yet working all of the other things ill work on addressing this is basically a beta currently and im trying to come up with a creative way of getting the data out of flash to a text file without having to put it in a big textfield and making ppl copy and paste a csv
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  9. #219
    Feb 2006
    Hingham, MA
    I tried to PM you Lost but it says you need to delete some messages before I can PM you.. On what we talked about....
    Yeah.. popups are bad
    When you come out with updates if you want to e-mail them to me you can e-mail them to [email protected] (preferrably as .rar files) or I can set up an account in a folder for you on my site.
    Let me know which way you would rather, and if you want to do the 2nd method let me know what you want as a username: & password: I will set it up tonight.
    PM me your reply
  10. #220
    NY
    as for the total look of the program just an fyi i will most likely try to keep it close to what it is. right now i am trying to get vb and flash to play well together some of the keystrokes etc arent executing when called from vb
    im am going to release it as a plugin for roadrunner
    by doing so it will be as easy to skin as rr with the same skin editer AND will also run standalone for FP ME CF, and MI users.
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  1. Replies: 120
    Last Post: 04-08-2008, 01:04 AM
  2. Article: E-tracking, coming to a DMV near you
    By VanMan69 in forum General MP3Car Discussion
    Last Post: 01-11-2006, 10:46 PM
  3. Article: Privacy of vehicle information being debated
    Last Post: 03-15-2005, 03:59 AM
  4. Mobile video in California
    By dacndar in forum LCD/Display
    Last Post: 11-30-2004, 03:36 PM
