maybe try a different version driver.. i dunno.
I just installed a Panasonic Touchscreen I got from digitalww.com (armen)---
the included Worcol software wouldn't install, so I used touchkit (egalax) and its working fine now.
BUT.. When I go into hibernation, then come back out of it.... the touchscreen doesn't work.
I have to close the touchkit software, then reopen it. Is there a fix for this? ANYONE!!!!!!
rebuilding carpc... kinda..
I recently had a similar problem with my new indash screen, none of the drivers would let the touchscreen work after hibernation unless i unplugged and re-plugged the USB cable. XP-SP2 didn't help either.
I ended up doing someting similar to this with the devcon utility ... monitoring the system for a power resume and then basically emulating a physical replug of the cable. Works great![]()
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Will try that for sure Ninja, I'll let you know tomorrow if that works... I haven't tried unplugging/plugging in the cable, only restarting the software.... so thats interesting.Originally Posted by Ninja Monkey
I figured out the problem, just need to close and reopen TouchKit - close before hibernation, reopen after...
Ok, so I got the opening of TouchKit problem fixed, BUT, I need something that can close it before going into hibernate, any suggestions?
Download this util: http://www.rpi.edu/~desimn/suspendtrigger/index.html
You will need to run devcon disable USB/vid_XXX*
on shutdown
and devcon enable USB/vid_XXX* on resume.
You need to get the USB device name of your touchscreen first by doing a devcon status *
You will obviously need to download devcon first - do a search.
Works well!
Although unplugging/plugging in the cable works, it's not necessary, isn't there a way to automatically close the TouchKit software when going into hibernation?
I'll still try devcon, I have it installed, but I can't get any of those scripts to work, is there a way to do it without the shutdown code? Just recognize hibernate and disable the USB device, then enable when coming back?
Sure, download a killtask app (that can kill a process via a command line switch) use that hibernate trigger to run it, and then restart it.. same idea as running devcon.
-arebelspy
See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
Originally Posted by xdjxklusivex
Originally Posted by arebelspy
Thats kind of what I had in mind, just no idea how to do that, lol... Basically I need a vb script that tells the app to kill the task (touchkit).. then have hibernate trigger run that vb script when going into hibernate... Any idea what killtask software/vb script I can use?![]()
Also, could you use a sendkeys script to just press "alt+F4" in the TouchKit window, I have no idea how this stuff works, just an idea though.
I REALLY appreciate the help guys, this project would be impossible without it.
