Results 1 to 6 of 6
Thread: DAM OS Wont Load
    Sep 2005
    DAM OS Wont Load
    Im trying to install Windows Media Center 2005 on my setup and it gives me this error:
    stop: c0000221 unknown Hard Error
    \SystemRoot\System32\ntd11.d11
    Anyone know why this is happening, btw i also tried installing XP Pro SP2 Integrated and same error. I checked connections and everything, mobo says WD 40G is detected.
    Thanks in advance
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    I wonder whether this is HW related problem (sure!) and whether you tried to swap some components to see whats causing it. I would start with your RAM stick(s) and PSU.
    Elsewhere
    1) When you format the hard drive DO NOT use quick format. Use a full format, as it will also run CHKDSK and work around any physically damaged sectors.
    2) Clean your CD or check it for scratches.
    3) Check your RAM and PSU like LagunaICE suggests.
    How about the Wiki?
    May 2005
    From the MS site:
    The following STOP message appears when a critical system file or other file needed to load Windows is corrupted:
    STOP: C0000221 unknown hard error
    <path>\<file name>
    Check here: http://support.microsoft.com/?kbid=101096
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Could be you CD drive too (I remember sothimg similar happened to one guy before)
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Constant Bitrate heypachuco's Avatar
    Mar 2004
    USA
    Yeah, try another CD drive.
    I had a similar problem and wasted hours trying to figure it out. I installed another CD drive and all was well.....
  1. FS: M10000, Morex 3688, 40GB 2.5", SLOT Load dvd/cdrw, 512mb ram
    By JuMpMaN6235 in forum Classified Archive
    Last Post: 07-13-2006, 11:53 AM
  2. OPUS point of load
    By lostreception in forum Power Supplies
    Last Post: 06-15-2005, 11:46 AM
  3. load soft ware to usb hard disk then load to comp
    By tracker92 in forum General Hardware Discussion
    Last Post: 08-29-2004, 07:57 PM
  4. The Os and The Car
    By SjLucky in forum Software & Software Development
    Last Post: 06-24-2004, 03:09 PM
  5. New install this weekend...Which OS should I load?
    By -al- in forum Software & Software Development
    Last Post: 09-27-2003, 07:58 PM
