Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 55
Thread: Autodimming monitor after 2 seconds of inactivity. (Solution inside)
  1. #21
    Low Bitrate dfk70's Avatar
    Sep 2005
    Sterling, VA
    Quote Originally Posted by RPM_VR4
    chronot150: Yes, most cars have a "dimmer" wire as part of the radio harness (it is usually the orange wire). It is 12V when your lights are on and 0V otherwise. I'm looking for something a lot more sophisticated than that though.
    RPM_VR4: You are correct in that most cars have a dimmer wire in the radio harness. But, it isn't just 0V or 12V. You can control the brightness with the dimmer switch so I would guess that the voltage on that wire is 0-12V not 0 or 12V.
  2. #22
    Constant Bitrate WhoIsThisGuy?'s Avatar
    Manchester, UK
    Quote Originally Posted by dfk70
    Does you're car have a "dimmer switch" which affects the dimming of the hu? In all the cars i've had, the wire is just a constant voltage, with the amount of dimming set by the hu itself.
    Anyways, i've been messing around with a few ideas and the best I've come up with is essentially a small micro controller which has a light sensor attached to one input and the above mentioned wire attached to another. If the light sensor falls to a certain reading or the headlights are switched on for greater than a set period of time, the micro controller can send an output. Now, this output could be to a pin of a serial port on the PC or maybe directly interfacing to some modification of the screen. For ease, probably best if its to the pc and then this would need to be a plugin to sit between. Interestingly, the output doesn't necessarily have to be a binary "on/off", it could send an analogue signal to allow the amount of dimmming to be altered based on the actual ambient light.
    Thoughts guys?
    M10K, Lilli 7", 512MB, 80Gb HD, slim CD-RW/DVD Combi, nLite Win XP, CentraFuse.
    Planned for years, built for ages, tested for a while, almost installed, never gonna be perfect...
  3. #23
    Raw Wave justintime's Avatar
    Apr 2005
    Who Is This Smart Guy?!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  4. #24
    Nov 2005
    RPM_VR4: I understand. Thanks for clearing that up.
  5. #25
    Sep 2005
    Sterling, VA
    Quote Originally Posted by WhoIsThisGuy?
    Yes, actually, all of my cars have dimmers. It controls the dash lights as well as the radio brightness.
  6. #26
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Suggest away at the GC forum
    Anyways, for those that want something in a frontend: its a very simple API that checks for idleness. Link
  7. #27
    Apr 2005
    hey Tipastar, this works very well!
    Would you have the knowledge to incorporate this VB6 code into your script, so that it can automatically calculate sunrise/sunset time based on your predefined coordinates? (same thing GammaControl does)
    Quote Originally Posted by tipastar
    I don't use these tools but here's a quick way to solve the time problem of when you activate your screensaver....
    Do everything justintime says in his post. Then, to only have the screensaver (power dimmer) activate only when it's dark you could write a quick vbs script to get the current time and if it's greater than the time it gets dark in your area, then activate the screensaver. Here's some code.
    <snipped>...
    2002 Honda CR-V
  8. #28
    Tainted Love Cris's Avatar
    Romania
    Another great idea from JIT! I hope you solve the problems as simple as possible without any extra hardware involved.
  9. #29
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Most cars are simply on/off to the radio. More expensive cars usually have a second wire for dim-level as well as the normal on/off (...and a few cars just have the dim-level). In any case, I always have my dimmer level on full bright.
    I really think the two best options here are:
    1) Sunrise/Sunset times calculated off ZIP-code or GPS. (software only)
    2) A light sensor connected to a micro or joystick axis. (better, but requires wiring extra hardware)
  10. #30
    Dec 2005
    Portland, Oregon
    Quote Originally Posted by justintime
    Check and see that you DON"T have 'password on resume' feature enabled in your screensaver control panel.
    I'm experiencing exactly the same issue. Password protect is definitely not checked. Pressing "Preview", it works as advertised. Waiting 5 seconds (what I have the timeout set at), it goes blank with an hourglass icon. Never asks for a password when I move the mouse, of course, but it doesn't make PowerDimmer work properly.
  1. Replies: 0
    Last Post: 07-08-2005, 05:08 PM
  2. A solution for powering 12v stuff inside
    By zootjeff in forum Power Supplies
    Last Post: 12-17-2004, 07:21 PM
  3. Best Carputer Solution. Ideas Inside!
    By voidunknown in forum Newbie
    Last Post: 08-25-2004, 12:35 PM
