Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Help with minlogon and booting directly into frontend
  1. #21
    Low Bitrate spudgunblunder's Avatar
    Aug 2005
    Do you have a link or relavent word to search for? I've'd and 'd but can't find ought yet.
    I really would appreciate a kick in the right direction as it's the only thing halting the 1st install.
  2. #22
    Jan 2003
    Ruston, LA
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #23
    Aug 2005
    Thanks for the link but I've actually already found that but it makes no sense to me. I know that to use minlogon you add that reg key
    HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon],"Config"
    But I don't know what they mean by
    (binary value, 5th bit)
    or
    Look at the cmiWlxAutoRestartShell extended property of the Minlogon component.
    Please help me to know my arse from my elbow.
  4. #24
    FLAC SFiorito's Avatar
    May 2004
    hmmm....I've never had to deal with this. Maybe they mean changing the Config value from 0x17 to 0x07?
  5. #25
    Aug 2005
    I don't know what these guys are on about in this thread.
    Can someone please explain what they mean by:
    If you click on a component node in a Configuration opened in TD on the right side panel you will see the component description and
    etc. On the bottom of the panel you see Advanced... button. If you click on it, you open Advanced Component Properties dialog where
    you can add/change any extended property of the component.
    You will have to change cmiWlxAutoRestartShell property.
    I this an edit you have to do with emdedded?
    Or is it just a case of adding the "config" with Hex value 17, which is a decimal of 23? (which I already have)
    binary:
    0000 17 00 00 00
    I googled "(binary value, 5th bit)" and found this.
    Is the 5th bit = 23?
  6. #26
    Aug 2005
    Found this.
    I think it may not be possible. I'll just have to live with it - unless I disable all error messages.
    and and some more...
  7. #27
    Aug 2005
    I can't even disable the error message!
    I've "Disabled Error Reporting" in System properties.
    Even added a reg key according to this.
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]
    "ErrorMode"=dword:00000002
    I think I'll just gouge my eyes out so I don't see it any more.
  8. #28
    May 2004
  9. #29
    Aug 2005
    Yes that works. Think it would be good for me to read up on binary/hex and reg keys!
    Thanks a million SFiorito and frodobaggins. You would have saved me over 8hrs if I'd bothered to take your advice.
  10. #30
    Jan 2003
    Ruston, LA
    Glad it worked out.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Replies: 268
    Last Post: 05-28-2012, 10:49 AM
  2. FAQ: Booting XP from a USB or Compact Flash Card
    By Bugbyte in forum The FAQ Emporium
    Last Post: 08-11-2010, 02:08 PM
  3. Best option for booting?
    By GreenBeast in forum Software & Software Development
    Last Post: 06-19-2005, 08:23 AM
