Results 1 to 4 of 4
Thread: Frodo's MatchVol with Mute Match also.
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Thumbs up Frodo's MatchVol with Mute Match also.
    I decided to stop using my Sound Blaster Audigy 2 NX via Toslink and use the SP13000's SPDIF out instead cause LES is more.
    The problem was that the volume on the SP13000's SPDIF was controlled by the WAV slider and not the Master VOL slider like the Sound Blaster. (I use the Griffin PowerMate USB to control and Mute my volume and it doesn't have options to map to the wav volume.)
    So I did some searching on the internet for an app that synchronized the two. And then I found Frodos MatchVol.exe and he also posted his Source code. I also saw another app that someone made that modified Frodos MatchVol but neither apps matched the two if one was Muted.
    Thanks to Frodo, I modified the matchvol.exe to add mute matching also.
    Here is the modified exe zipped up:
    Attached Files Attached Files
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    sweet!
    Variable Bitrate checksum's Avatar
    Feb 2006
    Columbia/MD
    Hi Leslie,
    I haven't started my project yet, but i am about to get a similar setup as yours. I am getting the SP13000 and was thinking about using the audigy 2 NX soundblaster. But before I invest I wanted to know why you decided to go with the onboard sound? How is the audigy 2 NX compared to the onboard sound in terms of quality and features?
    If I can get your input before I invest on the audigy or use the onboard sound.
    Thank You
    2005 Nissan Altima - Completed 2007
    2010 Nissan Altima - Coming Soon...
    Jan 2002
    Long Island, NY
    I'm about to sell my Audigy 2 NX here, cause I was having hibernate issues with it etc...
    Other than that, when it did work it sounded great, the onboard spdif sounds ok, but not as clean IMO, but it is reliable, works 100% after hibernation.
    I have tested many USB soundcards, and actually have one on order now. The new Edirol UA-1EX. If it doesn't work well for my CarPC, I will use it in my future Mini-Mac.
  1. Mute the Mic?
    By Mattkins99 in forum Road Runner
    Last Post: 01-10-2006, 03:30 PM
  2. How to make Frodo's RoutisLauncher work with iGuidance
    By dodgetimes2 in forum Software & Software Development
    Last Post: 09-10-2005, 02:47 PM
  3. Problem with Audio Mute in MM/Road Runner
    By wizz in forum Map Monkey
    Last Post: 04-21-2005, 10:13 PM
  4. Line In Mute problem with Radio...
    By ShawJohn in forum MediaCar
    Last Post: 08-20-2004, 06:21 AM
  5. Audigy 2NX with separate mute for Line-In and Mic-In
    By badandy4you in forum MediaCar
    Last Post: 06-03-2004, 01:04 PM
