Results 1 to 9 of 9
Thread: Hibernation Issues??
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    Question Hibernation Issues??
    I keep hearing of problems with hibernation, but can't quiet get it.Can somebody help me out. The main reason is i don't know if i should get 512 or 1GB (in case of hiberanation) of RAM. or won't it be worth the extra money for boot times??
    Final Touches
    Car: 2002 Mitsubishi Magna EI
    CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
    Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    I go with 256mb and it bores me a bit to wait about 10 seconds for the waking up
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Sharjah, Emirates
    256 is way too little, You got any problem with hibernation though??
    any people with 1 GB?
    Final Touches
    Constant Bitrate ThEScReW's Avatar
    Nov 2004
    Kortrijk/Belgium
    i Also hibernate from 256 mb ram, but my rams are RIMM RAM and works just fine, i gues about seconds. Why should it go slowly ?
    If your system runs at 205 mb of ram, then when it hibernates, it writes that 205 mb to your hard disk.
    When wakening op, it writes it back to ram so its the speed of the hard disk and the speed of your memory that makes the startup time difference !
    Nov 2004
    Italy
    if you look at the memory dump file size, it is the same size of the entire ram modules, not only the used portion.. so with 1gb you should expect to wait more than with 256mb, takes time to write 1gb of data to disk.. and do not forget that centrafuse is a .net application, it has the tendency to eat a LOT of ram in order to optimize performances
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Quote Originally Posted by ramy_zohair
    256 is not "way too little"
    This isnt a desktop computer here
    256 will be completely sufficient for the tasks at hand and actually decrease the time it takes to go into and resume from hibernation.
    I have been running 256 for 3 years and never a complaint
    Nov 2004
    Kortrijk/Belgium
    Quote Originally Posted by aoLhaTer
    Hier i have also no problkem, only xlobby eats about 50 mb of ram so that comes into 230 mb ram in total , and i have 256 mb so that's like a jippy
    Nov 2004
    Italy
    my point exactly
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    Sharjah, Emirates
    well, i'm sorry but my question was what are the problems with hibernation (something about USB devices???). thanks for the ram tips by the way.
    Final Touches
  1. Frodo take3 volume issues after hibernation
    By Will Albers in forum FP Bug Reports
    Last Post: 02-01-2006, 07:02 PM
  2. VIA MII issues w/ V620 hibernation
    By MobiTekLink in forum Wireless Communications
    Last Post: 12-01-2005, 02:41 PM
  3. Hibernation Issues
    By Matthew230 in forum Power Supplies
    Last Post: 08-06-2005, 05:41 PM
  4. Hibernation issues
    By Matthew230 in forum Map Monkey
    Last Post: 07-04-2005, 07:52 AM
  5. Hibernation Issues
    By Maeveth in forum Centrafuse
    Last Post: 01-23-2005, 12:36 PM
