Have I ho install and use mRouter??Originally Posted by jcdillin
i couldn't get hold of the widcomm 5.0.1.1200 drivers
whenever i found a link it just downloaded the .800 ones
jc - ok cool. let me know if you find out anything or progress at all
mRouter won't work with the 6680
you need to use the extended configurator
go to Symbian OS section and find the bit that says
'IsSymbian' change it to false
that is one thing that you need to do, how i got to the stage i'm at was a lot of trial and error, so i can't just reel off a list of task for you to complete and get a working setup
i've made this set, but not solved the problem
The problem is with the COM port. How do I have to set it in the bluetooth manager?
it should create a new serial port when you pair the phone with the computer
肚子笑痛了
S60 Install
how to do that? In the bluetooth control panel i have 2 place where do that:Originally Posted by jcdillin
- local service
- client apps
where??
i see that the wizard use the port COM5 that is the one of the bluetooth modem...
This is the log:
10/03/2006 0.27.50 MediaPlayer: WMPLAYER
10/03/2006 0.27.51 Version: 1.6.0 Beta
10/03/2006 0.27.51 Trial. Expires: 07/04/2006
10/03/2006 0.27.52 Keymap "Sample Key-Map for SE T610 simulating a mobile phone like keypad" loaded, 25 mappings found.
10/03/2006 0.27.52 SMS templates loaded, 5 templates found.
10/03/2006 0.27.52 Opening COM5
In the splash screen of Phoco (when it starts) i can read:
- Initializing phone
then...
- Reset phone
and immediatly the pc reboot !!!!
I've read something about to not use the serial port service, but to use the dial-conn.....someone can explain me better???
SOME LAST ADDS:
I tried to use windows bt drivers and phoco run good, but not the audio (this is because windows bt drivers don't support audio gateway). When i reinstalled widcomm bt drivers....phoco don't want to run...as sayd above, it causes the crash of the system....
PLEASE HELP!!!!!
P.S.: When i try the wizard config, at the step for searching com ports, i receive this error
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ObjectDisposedException: Cannot access a closed registry key.
Object name: "HKEY_CURRENT_USER\Software\Widcomm\BTConfig\Services".
at Microsoft.Win32.RegistryKey.ValidateState(Boolean needWrite)
at Microsoft.Win32.RegistryKey.OpenSubKey(String name)
at PhoneCtlWizard.Form1.FindLocalSerialPort()
at PhoneCtlWizard.Form1.btnScanPort_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
PhoneCtlWizard
Assembly Version: 1.5.0.23033
Win32 Version: 1.5.0.23033
CodeBase: file:///C:/Programmi/PhoneControl.NET/PhoneCtlWizard.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Infragistics.Win.UltraWinTabControl.v3.1
Assembly Version: 3.1.20041.15
Win32 Version: 3.1.20041.15
CodeBase: file:///C:/Programmi/PhoneControl.NET/Infragistics.Win.UltraWinTabControl.v3.1.DLL
Infragistics.Shared.v3.1
CodeBase: file:///C:/Programmi/PhoneControl.NET/Infragistics.Shared.v3.1.DLL
Infragistics.Win.v3.1
CodeBase: file:///C:/Programmi/PhoneControl.NET/Infragistics.Win.v3.1.DLL
Infragistics.Win.Misc.v3.1
CodeBase: file:///C:/Programmi/PhoneControl.NET/Infragistics.Win.Misc.v3.1.DLL
zBTHelper
Assembly Version: 1.0.2190.21340
Win32 Version: 1.0.2190.21340
CodeBase: file:///C:/Programmi/PhoneControl.NET/zBTHelper.DLL
OpenNETCF.Desktop.Communication
Assembly Version: 2.8.2181.32655
Win32 Version: 2.8.2181.32655
CodeBase: file:///C:/Programmi/PhoneControl.NET/OpenNETCF.Desktop.Communication.DLL
OpenNETCF.Net.Bluetooth
Assembly Version: 1.4.50709.0
Win32 Version: 1.4.50709.0
CodeBase: file:///C:/Programmi/PhoneControl.NET/OpenNETCF.Net.Bluetooth.DLL
Interop.BTSTACKSERVERLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Programmi/PhoneControl.NET/Interop.BTSTACKSERVERLib.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
hey jcdillin i just loaded up mobile impact (the front end i use) and phonecontrol just started working, i now get sound through the computer speakers and the comp microphone
dunno if thas any help or just rubbing your nose in it but at least now you know it works hopefully you'll be able to get it working
great info, i'll have to give it a shot
肚子笑痛了
S60 Install
could you share your experience of your configuration?Originally Posted by GreenBeast
Thank you in advance.
