Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: PhoneControls.NET and Nokia 6680
    Constant Bitrate teo256's Avatar
    Mar 2006
    Fossombrone (PU), Italy
    Hi all, this is my first post.
    I have a Nokia 6680 mobile phone and i'm interested to connect it with PhoneControls.NET that i have in my carputer.
    I read around that is so hard.....there is a way to do that? I basically need to make calls and receive calls....SMS are not too important.
    Please....help me.
    Thanks in advance.
    Bye bye
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    search
    Mar 2006
    i've searched, but not find what i'm looking for......
    Jun 2005
    Kent, England
    i've got a 6680 and you're right there isn't much specific to that phone but if you download phoco and get started then any problems that come up can usually be solved by searching specificlly for those problems.
    bear in mind that i have the phone connecting to phoco and i can dial out and accept calls but i have yet to get the sound transferred onto my pc, that is the current issue i'm trying to sort out
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    if you go into phoco.net and go to the forums, there is a symbian section that is dedicated to these phones. I've been working on getting my 6682 working as well.
    But I will give you a hint, with your phone, your going to have to disable symbian support in phonecontrol.
    肚子笑痛了
    S60 Install
    Mar 2006
    I'm trying to connect (via bluetooth) my Nokia 6680 with PhoCo. This is the problem: bluetooth driver creates 2 COM ports: COM4 & COM5. When I run the wizard of PhoCo, he found the port COM3 and when i run PhoCo, the system reboot automatically.
    How can I solve the problem?
    Jun 2005
    Kent, England
    how far have you got jcdillin?
    i can call out and receive calls, i think it also sends messages, i've exported my phonebook using pbConverter and thats working.
    the only thing which doesn;t currently work is the sound on the PC
    as far as me or further?
    Mar 2006
    I'm so far from you, i'm at the starting point....phoco don't want to recognize the right COM port!!!!
    I'm downloading right now the lastest Bluetooth driver (v. 5.0.1.1200), I hope that can solve the problem
    Can you tell me ho you worked? From the beginning
    May 2003
    Miami, FL
    Quote Originally Posted by GreenBeast
    Right now i'm at the same place as you, i'm just making sure this is working perfect before I move onto the sound issue.
    Still working on getting the latest widcomm drivers first.
    肚子笑痛了
    S60 Install
    May 2003
    Miami, FL
    Quote Originally Posted by teo256
    Well first things first, you need to finish the wizard before anything else.
    肚子笑痛了
    S60 Install
