Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Moving Hard drive
    Jun 2005
    Kent, England
    Moving Hard drive
    Is there any good ways to install windows and software on a drive indoors and then put that drive in the carPC and have it work?
    Elsewhere
    Install Windows inside on the same PC you're instaloing in teh car.
    In other words, no.
    How about the Wiki?
    Jan 2005
    Only if you have the exact same mobo/graphics/network/soundcard and so on. So not really plausible unless you have a dedicated test setup.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Shouldn't be a problem, just make sure you have to hand any other drivers you might need.
    One proviso, when you have finished with the harddrive indoors.
    assuming windows XP
    Right click my computer
    Manage
    device manager
    ide ata/atapi controllers
    right click on the master IDE controller
    update driver
    no not this time
    install from specific location
    Don't search I will choose driver to install
    Standard dual channel PCI IDE Controller
    if 2000 then when you right click on master IDE choose properties
    then driver tab, then update driver
    display list of known drivers
    and then again choose Standard dual channel PCI IDE Controller.
    Jun 2005
    Kent, England
    thanks for the replies guys
    enforcer, so it should be alright?
    its just i don't wanna sit in the car with an extension lead for an hour so, rather get windows and sp2 installed along with my frontend and freedrive as well as other software i need
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Yes, it should be OK, the main cause of bluescreens on reboot when you switch a harddrive from PC to PC is the inability of the OS to find the harddrive and this is caused by the IDE drivers being specific to the MB.
    Therefore the above sets the driver to a generic IDE driver. The OS will then go through swapping all the other drivers around, therefore it is worth having a CD with all the drivers for the other PC ready. (although XP usually has most of them, it is normally best to put the manufacturer specific where possible).
    Jun 2005
    Kent, England
    ok cool cheers
    is it worth installing things like BT dongles indoors or wait till its working outside?
    Maximum Bitrate 2Fast's Avatar
    Feb 2005
    Bristol UK
    Enforcer is right, i installed my OS on my main PC then transfered it to the car before installing drivers.
    Jun 2005
    Kent, England
    excellent. especialyl as its taken me ages to get phoco working.
    i don't wanna repeat that outside
  1. Hard Drive Issues in a Vehicle Computer
    By DarquePervert in forum The FAQ Emporium
    Last Post: 02-23-2008, 02:35 PM
  2. Hard drive dilema.... 2.5" or 3.5"?
    By 3Tripnip in forum General Hardware Discussion
    Last Post: 01-14-2006, 01:30 AM
  3. Help!!! laptop hard drive
    By ashbosh in forum General Hardware Discussion
    Last Post: 07-15-2005, 02:34 PM
  4. Laptop Hard Drive in carputer...
    By Powers in forum Newbie
    Last Post: 05-08-2004, 11:37 PM
  5. Laptop Hard Drive Problems
    By Powers in forum General Hardware Discussion
    Last Post: 04-28-2004, 08:21 PM
