Results 1 to 8 of 8
Thread: What is the best GPS Navigation soft for PC(Laptop) for West Europe?
    luk
    luk is offline
    Apr 2006
    Question What is the best GPS Navigation soft for PC(Laptop) for West Europe?
    I need : 1.Laptop
    2.GPS Navigation soft for PC(Laptop) for West Europe
    3.GPS Receiver with SiRF III chipset connected to Laptop
    I want to travel in Germany and i need a GPS Navigation soft but for PC and NOT for PDA!
    What is the best GPS soft from this :
    ViaMichelin MapSonic/MapStore
    InfoMap Navigator 4.4 - Europe
    Route 66 Europe 2005
    Microsoft Autoroute 2005
    Alturion GPS Professional With European Maps v6.0
    Destinator 3
    Aeromap
    What you recommend me for GPS Receiver :
    Holux GR-236 or GlobalSat BT-338 ?
    What is the last version of Viamichelin for PC?
    ViaMichelin Navigation 4 Europe
    http://www.shop.viamichelin.co.uk/sh...?catalogID=725
    This will work for PC ?
    What's different between ViaMichelin Navigation 4 Europe and ViaMichelin MapSonic/MapStore ?
    Does ViaMichelin MapStore 3.5 run on a pc then ? all i can see on their site is pda
    Yes it works on a PC, Mapstore is the PC part and Mapsonic is the PDA part. The PC doesn't have postcode search like the PDA and isn't really touchscreen friendly at all..
    What is the last version of ViaMichelin MapSonic/MapStore ?
    thank you very much and I wait your reply
    Feb 2006
    I use infomap navigator
    Hard to say what is "best", there are probably few who have tried many of them. Good luck collecting information on the lot.
    I use infomap navigator, it is ok with a touchscreen and have postcode search. It also have a "carpc mode" with on-screen keyboard. Perhaps that don't matter to you, if you're going to use a laptop. You can buy it with a sirf III usb gps included if you like.
    My reason for choosing infomap navigator was that it runs with linux - no other navigation sw do.
    luk
    luk is offline
    Apr 2006
    But do you have : InfoMap Navigator 4.4 - Europe ?
    Or do you have UK version of Infomap?
    InfoMap Navigator 4.4 Professional Europe
    http://www.directions.ltd.uk/moreinfo.php?id=1120
    Postcode Locator (UK only)
    Search about postcode it's working just in UK
    - New additional functions such as:
    - History saves your last ten destinations
    - Bypass allows you redirect your route to avoid traffic jams and roadworks
    - Speed Warner alerts you when you exceed speed limits
    - Postcode search for all of Europe
    - Map language changes the language displayed on your map
    * In order to succesfully install ViaMichelin Navigation 4 on your PC, it is required to perform a synchronisation with your PDA. Otherwise, it is impossible to install the software.
    How can i install ViaMichelin Navigation 4 Europe if i don't have PDA,because in their site it tells it's impossible to install it without PDA
    How many CD's ( DVD) is InfoMap Navigator 4.4 - Europe , if you have this?
    I can use it with my Laptop?
    Have you try it already in West Europe? ( germany,france,spain,austria,italy etc ?
    Because i want to travell in germany,and i need a GPS navigation software
    thank you
    May 2005
    Derbyshire, UK
    Download the manual and have a read.... http://www.viamichelin.co.uk/viamich...serGuideUK.pdf
    I am just downloading it myself, but I believe the PC part is no longer like mapsonic with navigation but just for planning.
    http://www.mp3car.com/vbulletin/show...3&postcount=42
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
    luk
    luk is offline
    Apr 2006
    What is the newest(higher) version Viamichelin of Mapstore (3.5) and Mapsonic(2.5) what it can be use it for navigation and it's work good, or exist higher version like this what will work GOOD for navigation in West Europe?
    Do i need to some patch to manage it working Viamichelin Mapstore and Mapsonic ?
    Or if Viamichelin isn't enough good,you can tell me other soft what will work good with a laptop in West Europe
    thank you very much
    Constant Bitrate m-ruiter's Avatar
    Jul 2005
    Kortenhoef
    I'm using iGuidance Europe, and it does the job for me.
    It's also supported in almost every frontend.
    http://www.inavcorp.com/products/igu...21_europe.html
    Feb 2006
    Quote Originally Posted by luk
    I have the Europe version, because I live in Norway.
    I haven't looked much at that yet, but it is definitely able to find street addresses in Norway.
    I don't know about this Michelin thing. If it says PDA only, then it probably is PDA only. Infomap navigator, on the other hand, runs on PCs that have linux or windows.
    You get one DVD, or several CDs. The DVD contains maps for western Euroupe except UK, as well as all the software. If you buy your GPS elsewhere then you may need a driver for it too. Linux already has with a driver for the optional supplied GPS.
    Sure, if your laptop is an ordinary intel-compatible one, and you have either linux or windows on it.
    All of those, and many more. A full install is a bit over 7GB, but you may select to not install some maps to save space.
    Helge Hafting
    May 2006
    I'm using mobilenavigon from www.navigon.de for laptop.
    Very easy and very fast responding, clear interface
  1. navigation carpc europe
    By [mp3]neo in forum GPS
    Last Post: 09-26-2005, 08:45 AM
  2. Replies: 7
    Last Post: 10-27-2002, 12:13 PM
  3. Replies: 5
    Last Post: 10-24-2002, 12:00 PM
  4. simple soft to test USB GPS receiver
    By felix99 in forum GPS
    Last Post: 10-08-2002, 03:23 PM
  5. GPS Software for Europe
    By mtmsol in forum Software & Software Development
    Last Post: 01-21-2002, 10:58 PM
