Results 1 to 10 of 11
Thread: IBuscomm
    Newbie doubletop's Avatar
    Apr 2006
    New Zealand
    IBuscomm
    I am trying to get IBuscomm working, I've unzipped the software, have set SetVisible=True and run ibuscomm.exe Task manager reports the software as running but I don't get any display.
    I have the Resler I/F which works fine with other monitor/analysers. Is there something I have missed or that isn't documented?
    What is supposed to happen?
    FLAC sama's Avatar
    Feb 2006
    London, UK
    u need to set the com port to the same one your resler interface has.
    also, check link in my sig dude, should help you out.
    Apr 2006
    New Zealand
    So you are saying that if it can't find a device on the com port it won't run the display?
    Strange, but thanks I'll check it out but had set up the com port
    FLAC sama's Avatar
    Feb 2006
    London, UK
    yes exactly. use device manager to find out the com port ur using, or in ibusanalyser, u should see the comport. chances are it will be com 2, 3 or 4 (since ibusanalyser works and it only supports the first 4 ports).
    also, check what processes are running when u launch ibuscomm (ctrl+shift+escape). if u ran ibcom with the wrong port, it will hang in memory so make sure u close down any running instances of it.
    checkout the latest mods darth and I have done to ibc here
    Apr 2006
    New Zealand
    Had to give it a go despite it being pitch black outside. No luck, I've had Ibus monitor working fine before and the I/F is on com1, I've got the Ibuscomm.ini set to com1 and my GPS is on a USB port maquerading as com4.
    I'll get some time in daylight and do a more controlled check through.
    Thanks for your help and I'll get back
    Low Bitrate DarthTater's Avatar
    Feb 2006
    Join me and together we shall rule the galaxy as father and spud.
    Check your contention management settings. Depending on the version of IbusComM you're using, the software setting (ContentionManagement=0) may be the only valid setting.
    See my install here:
    540i / 320i Mods
    Get a free and lightweight blog here
    iPhone Hacks
    Thought Soup
    Registered User
    Aug 2004
    Quote Originally Posted by doubletop
    i have the same setting, but still doesnt work
    it work for me before flawlessly...but after since i formated my computer, my iBUS doest work anymor. ibusanalyser works for me tho on com port 1. But when i run ibus, then RR...it crashes and says "runtime error 13"
    any idea?
    Variable Bitrate redbullah's Avatar
    Mar 2006
    Belgium
    i am also experiencing weird problems with same adaptor.
    it may be a driver issue. only ibus thing that works in my car is steerwheel next, prev, + , -
    strange
    Feb 2006
    Depending on the options your vehicle has, the steering wheel controls may be the only thing residing on the i-bus with the rest of your entertainment features operating on the k-bus. Use something like the ibus analyzer to see if you are seeing data packets from your radio etc.
    540i / 320i Mods
    iPhone Hacks
    Thought Soup
    FLAC sama's Avatar
    Feb 2006
    London, UK
    and make sure you press "select all" devices, and that "live update" is enabled
  1. BMW IBus-Heads
    By DarthTater in forum RR Plugins
    Last Post: 12-16-2014, 03:51 PM
  2. ibus? anyone use...
    By djgman in forum Media Engine
    Last Post: 07-18-2008, 06:15 PM
  3. RR and I-Bus version 2.0 beta
    By CdRsKuLL in forum Road Runner
    Last Post: 03-05-2008, 07:48 AM
  4. Possible new feautre in IBusComm
    By Marchello in forum Road Runner
    Last Post: 10-04-2006, 08:42 PM
  5. IBUSCOMM help
    By phita23 in forum Software & Software Development
    Last Post: 02-08-2005, 10:30 PM
