Unfortunately, i can't move up one level form c: this object doesn't able to.
I should simulate it...
The program is designed to be frendly... it doesn't handle all errors.
The latest version crashes with an error when I was trying to browse a directory under "C:\Documents and Settings\xxxx" where xxxx is the username. When using Windows Explorer to browse that directory, I get an error saying access is denied. Seems like it is not handling error very well.
The error from Image Viewer is "Run-time error '52': Bad file name or number"
Also, would it be possible to move up one level from C: drive and show all the available drives? Something like the My Computer view in Windows Explorer?
For some time now, I'm facing a big problem with ImageViewer!!!
The buttons do not follow the commands….![]()
And more concretely as an example, the command "SENDKEY? N" does not correspond to "Next"!!!![]()
Could somebody write clearly the sequence of commands?
Regards to everyone!!!
Virtuousness & Daring...!
Sendkey has the following syntax for RR
B13,329,416,65,58,"sendkey;{N}",
I don’t use imageviewer but I do use the sendkey command so I know that the above works.
If your application does not receive the command maybe you can set the focus to the application and then send the command.
Something like this
B13,329,416,65,58,"ACTIVATE;imageviewer||sendkey;{ N}",
The above will set focus to the application that has the name “imageviewer” and then it will send the “N” character using the sendkey command
The road is long but we are getting there.
I downloaded just now thw imageviewer. As I check it I have to say only one think for the moment. Except my thanks for the effort.
When in Slidemode there should be an option for random slides and even for the photos in subfolders. So that you dont have to see always the same photos.
It is the same big problem that RR has with image viewing.
That's what the screensaver for the windows "my pictures" do.
Do you think it is possible?
Unfortunately the problem is continued…![]()
This is my Sequence Commands...
MEDIACAR Skin
MEDIACAR Picture Skin
ImageViewer_Off.png,ImageViewer_Off.png,ImageViewe r_On.png,ImageViewer_Off.png
/, A, x, y, w, h, color R;RGB, G, B
/, I, x, y, w, h, Code;INDICATORCODES
I-MUTE,699,519,99,82,"MASTERMUTE"
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B-01,0,518,101,82,"CLOSEWINDOW;ImageViewer||EXIT",
B-02,104,524,96,75,"SENDKEY;{B}",
B-03,201,516,96,82,"SENDKEY;{A}",
B-04,303,516,95,82,"SENDKEY;{Z}",
B-05,401,514,96,82,"ACTIVATE;ImageViewer||SENDKEY;{P }",
B-06,498,514,97,82,"ACTIVATE;ImageViewer||SENDKEY;{N }",
B-07,604,513,94,82,"SENDKEY;{S}",
END
None of these commands semms to work![]()
maybe you can try removing the - after the B
make this B-02,104,524,96,75,"SENDKEY;{B}",
like this B02,104,524,96,75,"SENDKEY;{B}",
It could be that.
Unfortunately the problem Continues…![]()
Necessary need!!!
