Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: hibernating windows98
    Mar 2002
    haiti
    Arrow how to add hibernating to windows98
    is there a whay to enable hibernation on win 98 ?
    that would be a great alternative to shuttingdown
    Apple Ipod 20gig 4th gen black and white. Saves you lots of time. and a pocketpc with wifi for the ocasional email cheking and mapping at a hotspot.
    Apr 2001
    Here, There, Everywhere
    Re: how to add hibernating to windows98
    not by default, but is you can locate a 3rd party utility to achive the task, I would love to hear about it!
    Project - GAME OVER :(
    Oct 1999
    New Zealand
    Have you considered using "suspend to ram" instead? That is what I use and it is great.
    See http://www.geocities.com/wired_ride/str.htm for details.
    Honda CRX. Custom enclosure.
    Supermicro SED MB (Onboard sound and TV-out). Celeron 700. 64mb ram.
    40 GB Seagate HDD on vented foam mount.
    Keypower DC-DC KP-DX 250H ATX 250W.
    Delvcam 5.6" TFT LCD Monitor.
    Old headunit (ripped out tape mechanism added audio inputs on back).
    X10 RF mouseremote.
    "Wired Ride" web site
    The Australia/New Zealand mp3car Portal. Join now!
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    hey, will this function on sproggys too? I heard that the supply is on full power eaven with str on, wich currents is the pc using? if its only one or two, I could just make a weaker supply witch only provides the str-currents, in small amounts? and then make the remote cable to the psu get volts at the same time that you resume from str??
    Mar 2002
    haiti
    if it saves it on the ram doesn't it need a power flow ?
    if i could find the hibernation instead that would be better because the car could be of and back on and windows would not have to boot and the mp3 player ould not have to restart the last played song
    FLAC Mastero's Avatar
    Aug 2001
    India
    Jul 2000
    Ottawa, Canada
    babas151 -
    using STR requires power to keep the data in the ram, althought it should be an amount small enough not to effect your battery's life
    with hibernate you can completely shut down your computer (no power used) but it needs to properly shut down.
    unfortunately i believe both hibernate and STR require motherboard support (ie won't work on just any computer, my sockey 7 in the car doesn't but its a few years old)
    [SIZE=1]'91 Nissan Stanza
    [XXXXXXXXXXXXXXXXXXXX] XX% Completed -
    Car Totaled and i bought a 20G mp3 player
    http://machs-fuel.tk
    a DIY video projector page
    Sep 2001
    I have the same question as jol, does the Sproggy supply effectively support STR when using a STR-compliant motherboard? i know with my abit bh6, putting my machine into suspend did not reduce the current consumed by the PC at all and my battery was dead within 3 or 4 hours. Although I'm not certain my motherboard is compliant, I am using the MK 2.5
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    I don't think the BH6 is STR compliant. The manual says it supports ACPI, but only in part. I noticed it switches off the fan headers in suspend, but from what I can tell, it leaves all other devices powered up and doesn't send a "sleep" signal to the power supply.
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Hibernate did not come with win98...you can get it with winME though. or XP (or even 2k I think)
    Hibernate allows you to suspend and completely power the computer off...unplug...(stores to disk)
    Suspend to ram keeps the info in ram unless power is disturbed, then the ram is emptied, and it is no longer suspended...just shut down.
    You obvously need the newer hardware to take advantage of it...not APM but the ACMI (or whatever the acronym is)
    I have a mobo from 3 years ago that has the compliant hardware.
    I think most of the ATX motherboards will be compliant...again just search the manufacturers web site.
