try adding them all to a batch file, and make the batch file the shell? should work..... you might need to adjust/make a .pif file to have the programs start minimised where required.....
I have windows ME, cobraIII set as the shell, but I need to run 2 separate programs, IRassistant and winlirc, minimized so they hide themselves in the system tray. is this possible when cobraiii is set as the shell (or any other program set as the shell)? if so how do i do it? Thanks!
Project - GAME OVER :(
or he can add it to registry in the "RunServices" part of it.
I believe i posted the registry path one time...or search on the web for that info
abcd-1
good call
charles, did you read my post about making programs the shell in windows NT/2K/XP the other day? Was quite impressed with that discoverry......![]()
yep sure did....i have added that info to my notes
I knew it was out there just never bothered messing or searching 4 it... atleast someone here is hard at work![]()
abcd-1
