You might be able to modify the bitmaps and then "re-compile" the PRC file with metroworks Codewarrior 7 program.
Apple Ipod 20gig 4th gen black and white. Saves you lots of time. and a pocketpc with wifi for the ocasional email cheking and mapping at a hotspot.
GTI - Palm IIIe controlled with Radio faceplate hack for keyboard control of WinAmp w/ Vocal Genre playlist loading.
VW Bus - 10.4" vga lcd. Loaded with same software as above.
Hey babas151, here's a program that installs on your Palm and let's you change the actual PRC file. I tried it yesterday and changed some bit maps on some of my apps. Only took like 20 minutes to figure out how to use it and it works pretty good.
Quartus RsrcEdit
Quartus RsrcEdit provides templates for editing:
Form (tFRM)
Menu (MBAR)
Alert (Talt)
String (tSTR)
Icon (tAIB)
Application Name (tAIN)
Version string (tver)
Bitmap (Tbmp) resources.
thanks but how do i get he source code on the palm ?
you DON'T need the actual source code at all. You modify the "oringinal" PRC. This free Trial app has a lot of possibilities to make modifying ANY PRC a snap. You just select the app you want in the list then click open, scroll through the different Tbmps (bitmaps), or tFRM (forms that have fields in them ie: you can change font sizes and words in here) .You can change the icons that appear the palm desktop, change or add bitmaps, change font sizes, the list goes on and on.
kool i'm going to try it then . I alreasdy downloaded it thanks alot man
yep you could even get rid of the "unregistered" writing on palmAmp under the plug symbol. You could also "increase" the font size on PalmAmp song title from bold to Large or even "Bold Large". You could even change the PalmAmp splash screen to say registered. After spending the last couple of day's with this app i've customized some of my apps to suit my needs, and i'll think you'll agree it's a must need app for anyone wanting to change the appearence of their Palm Programs.
