Results 1 to 4 of 4
Thread: Palm VNC to control winamp ?
    Mar 2002
    haiti
    i had a soft for my palm once that was suposed to show you the screen of your pc on the palm but i never got it to work i couldn't get the palm to connect to the PC but now i figured that out .
    HAS ANYONE EVER TRIED THE SAME THING ?
    Apple Ipod 20gig 4th gen black and white. Saves you lots of time. and a pocketpc with wifi for the ocasional email cheking and mapping at a hotspot.
    Feb 2002
    Ontario, Canada
    Tried it and got the same thing......nothing. The reason is because Palm VNC will only work over a normal TCP/IP network connection. I've read that you can set it up to link through your palm cradle ( as i'm guessing you are trying to do ) but it's supposed to be pretty complex. Try this link, i know it's for Win2K but it might help you out or at least give you an idea of what's involved.
    Connecting a Palm Pilot to Windows 2000
    Hope this helps you.
    GTI - Palm IIIe controlled with Radio faceplate hack for keyboard control of WinAmp w/ Vocal Genre playlist loading.
    VW Bus - 10.4" vga lcd. Loaded with same software as above.
    Feb 2002
    UK
    I use VNC a lot at work over a network, but have had it working at home fine, using the Palm to control the PC. It's hard work, as the screen area is very small, so a lot of scrolling is involved. Also, I've only had it working over a serial connection, so it's not amazingly fast.
    To get the Palm to connect, you need to run a Palm>TCP mapper. I use MochaPPP from http://www.mochasoft.dk/
    Once Mocha is set up (make sure Hotsync is closed first) and put the Palm in it's cradle (or plug in a serial lead to it) and Mocha should report a connection (you need a 'proper' cable because the DTR line is used to check the connection).
    Run the VNC server on the PC (make sure you download the correct version - you need the version with server-side scaling from http://www.btinternet.com/~harakan/PalmVNC/)
    Run VNC on the Palm, enter the IP address of the PC (you'll need TCP IP installed on the PC), and in a couple of seconds, you
    should see (part of) the windows desktop.
    It's a lot easier than it sounds. hope this helps.
    bum. broke it.
    Feb 2002
    I've not got VNC running on my CE device, but managed to use Mocha PPP mentioned above to control a Winamp http server from the PDA.
    The mocha PPP implementation seems pretty good IMO.
