- Did you ever run RRConfig? That is where your initial setup of the program.
- This is the wrong place to post. Put it in RR subforum. Being say that, do not post the same question in RR subforum again. The mod will move it (hopefully).![]()
Ok, I somehow cannot find how to load music into Road Runner.
I have the application installed under Program Files and all my music is located under My Music folder. How do I get the music into Road Runner?
I've tried and even read the FAQ but cannot figure it out.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
I did run it, I will look more into it and post my results. This is twice I post in the wrong place![]()
Ok, I got it to load, but why won't it play? I'm just doing this on my regular computer to test things out.
Basically in RRConfig you give it the Music Path and Winamp Path.
Then Run RoadRunner
Select Audio player and click on playlist to load.
If you see the list, click play/select or whatever the button on the skin is to play. Double click on the song title also playing it.
What if I don't have Winamp installed? Can I use a different application?
no to what? There were two questions.
you should probably install it then...maybe RR was programed to only work with winamp.
Originally Posted by salvi
and only one answer, you need winamp for RR to run.
RTFM
How do I install Road Runner ?
