Results 1 to 3 of 3
Thread: mpxplay troubles
    May 2002
    Unhappy mpxplay troubles
    Hi,
    I'm having a *slight* problem with mpxplay:
    when I start it up, I can scan my CDROM for MP3s and MPYPLAY will start to play the first file.
    But after some time (~60s) there is no sound anymore, the CPU-load goes up to ~250% (but the CPU doesn't get hot...) and the equalizer is moving slooooow... I can still browse through my playlist, if I select another song it will begin to play but you can't hear anything and the CPU-load and the equalizer react just as described above...
    System: P100, 64MB RAM, AWE64 - any more information needed?
    Please, help me...
    Tim
    Dec 2001
    It was working fine on mine when I used the CD. Whenever there were problems (skips and such) I would try the suggestions in the readme file. Just play with the buffer settings and such.
    May 2002
    Solved...
    Hi,
    just wanted to let you know that I solved the problem my using another motheboard - the old one wouldn't boot from HD so it was faulty anyway - with the new MB and the same processor, it works like a charm
    Tim
