Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 44
Thread: Laptop Half Arsed Shutdown Control System...
  1. #11
    FRP
    FRP is offline
    Jul 2004
    UK
    Having just restarted my project after yonks of not doing anything, my EPIA now refuses to output video... so I am now using an old P3 1.2 laptop, so this could be exactly what I need.
    However, upon downloading to test, it comes up with .net framework error:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at ShutControl.ShutControl.GetFileContents(String FullPath, Int32 j)
    at ShutControl.ShutControl.EWFCheck(Boolean EWFWrite)
    at ShutControl.ShutControl.ShutControl_Load(Object eventSender, EventArgs eventArgs)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ContainerControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.2032
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    ShutControl
    Assembly Version: 1.0.2427.10689
    Win32 Version: 1.0.2427.10689
    CodeBase: file:///C:/test/ShutControl.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    Microsoft.VisualBasic
    Assembly Version: 7.0.5000.0
    Win32 Version: 7.10.6001.4
    CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
  2. #12
    Jul 2006
    British Columbia, Canada
    Hi,
    This VB app is going to be really helpfull. Could you please add an option to standby instead of hibernate and also the option to disable the restart feature.
    Thanks a tonne....
  3. #13
    Jun 2006
    Quote Originally Posted by rumy View Post
    Hi,
    Thanks a tonne....
    Hi,
    If you can outline in a bit more detail what you would like to do. From what I gather you want to...
    Battery detected > Laptop enters standby
    AC detected > Laptop resumes from standby
    In this instance, would you want the laptop to load any applications when resuming from standby - or simply resume? In this case, I can make a simple fix whereby you enable the EWF option, but instead of shutting down, it will enter standby.
    Wait for the new release
    '98 Peugeot 306
    Project Status: I sold it ages ago!
    ShutControl
    The ultimate shutdown control software for laptops.
  4. #14
    Jun 2006
    The scope is pretty much endless on all of this, I could make it turn off when the battery hits a certain level, or perform a certain action. If anyone does have any more requests, I'll be glad to try and put them in.
    Remember though, this is the first ever time I've used VB - so my coding is horrific and it is nowhere near optimised, but I'm glad I've got this far.
    '98 Peugeot 306
    ShutControl
  5. #15
    FRP
    FRP is offline
    Jul 2004
    UK
    Is there any reason for the error I am getting at the top?
  6. #16
    Jun 2006
    Are you trying to load the app from c:\Test\ShutControl...or are you letting the installer put the files in the correct place? If the app is loading from C:\Test\ShutControl - in versions previous to 1.2 it will still run as long as the Config folder is present in the same directory.
    That kind of error derives from the application using a variable, when it is not set. Which sounds like you don't have the config folder present. Download the latest version (1.3B) and execute it, and let it install to its default directory (it does have an uninstaller, so its ok).
    It looks like you have Framework 1.1 installed, try upgrading to 2.0 (see first post error section).
    '98 Peugeot 306
    ShutControl
  7. #17
    Low Bitrate dontpntpool's Avatar
    Aug 2006
    IA
    this is one of the reasons I use the older versions of vb...I hate all the bloat in .net and the requirements.
    btw looking good...
  8. #18
    FRP
    FRP is offline
    Jul 2004
    UK
    Sorry... I missed the install program and was trying to extract and execute the app directly. (You said in your first post just download, extract and run and the prog will install itself - didn't realise all I had was one of the updates!). Got it now though. Cheers.
  9. #19
    Jun 2006
    No worries, I changed the text in the first post now to reflec the need download and run
    '98 Peugeot 306
    ShutControl
  10. #20
    Aug 2006
    IA
    ok just to review so far, please correct me if I am off base
    Purpose
    Shutdown control is a program for laptops that is a laptop battery watchdog that does the following:
    1. Automatically shutdown, suspend, or hibernate a laptop based upon user settings and the laptop battery status.
    2. If automatic hangs it will try and force the situation after a specified timeout to try and protect the car battery.
    3. Launch user specified applications before and after hibernation
    What this can't do
    Turn on the laptop when the ignition is triggered. One of the following hardware solutions must be used:
    1. Hard wiring the power button on the laptop (here)
    2. Using Wake on Lan (here)
    Needed
    To fully emulate the power controllers that the desktop motherboards use for cars the following things are still needed:
    1. Read the car battery level to prevent drained car battery, even during Standby/Sleep, to force laptop power off
    2. Delayed remote control for audio amplifiers, to prevent the thump
    3. control power to other laptop accessories (for laptops with external powered drives etc)
  1. Replies: 85
    Last Post: 07-09-2007, 04:44 AM
  2. Replies: 1
    Last Post: 02-03-2004, 07:07 AM
  3. Auto shutdown when laptop goes to battery
    By W6-Ryan in forum Software & Software Development
    Last Post: 09-02-2003, 02:03 PM
  4. Wanna power this laptop since I fried my system today.
    By MikeHunt79 in forum Power Supplies
    Last Post: 07-07-2003, 11:24 AM
  5. control laptop from cd changer?
    By aharrover in forum General Hardware Discussion
    Last Post: 12-11-2001, 01:17 PM
