Results 1 to 10 of 12
Thread: How to properly (and easily) hack using ResHacker.
    Raw Wave justintime's Avatar
    Apr 2005
    So I hear that many of you are going through pains attempting to modify iGuidance using ResHacker. Here is the proper way to do it.
    You will need:
    1) Resource Hacker 3.4.0 This is a Windows Resource Editor, which gives you access to modify dialogs, bitmaps, icons, etc. for some application files.
    2) GoRC: This is a freeware resource compiler. It will turn a .RC file into a .RES file.
    Summary of procedure: Export .RC from Reshacker, modify resources, compile a .RES file from the .RC, and import .RES file using Reshacker.
    Let's assume you want to modify all the bitmaps for iGuidance.
    Procedure:
    1) Launch ResHacker, and open the executable file you want to modify.
    2) In the left side, you will see a list of resources. Select the folder icon for Bitmap.
    3) Select Action-> Save Bitmap Resources. This will save all the individual bitmap files, as well as .RC file. The .RC file is a pure text file that contains the mapping between the bitmap name and the resource number that it had assigned inside the exe file.
    4) Modify all the bitmaps using your favorite image editor.
    NOTE: Don't get discouraged, read the following which makes the import back into iGuidance real easy:
    5) Because ResHacker cannot import back an .RC file, you need to compile it into a .RES file, which ResHacker can import just fine. So... first copy the GoRC.exe file into the same folder where all your bitmaps and .rc are located. Assume c:\bitmaps\, and that you have a file bitmaps.rc inside.
    6) Open a cmd line (Start->Run, and type cmd). Go to the folder c:\bitmaps and then you are going to run this command:
    gorc.exe /r bitmaps.rc
    7) This will output a file bitmaps.res. Open ResHacker, Open the iGuidance executable application file, and select Action-> Update All Resources. Choose your .RES file, and save changes.
    This works with other resource types, such as dialogs etc.
    Piece of cake!
    -=J
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Oct 2004
    NY
    wow, that's cool... thanks for sharing this.... can't wait to get my own copy of ig3....
    Constant Bitrate Playerbeat's Avatar
    Apr 2005
    San Jose, CA
    Nice, Thank you. As soon as CdRsKuLL finishes Freedom, (a skin for RoadRunner) I think I'll do up my copy of ig3 to match.
    7" TouchScreen Carputer
    Rockford Fosgate 1501BD and Rockford 551s
    12" MTX 9500 in a SS* or a 12" Brahma in a SS*
    ZAPCO COMPONENTS in front and RFs in rear
    2 YellowTops and a 200amp Iraggi Alternator
    *Snell Shell box from nolteaudio.com
    Apr 2005
    San Jose, CA
    I keep getting this error. What am I doing wrong?
    CMD:
    C:\Documents and Settings\Front Room Stroke\Desktop\ig>gorc.exe /r bitmaps.rc
    GoRC.Exe Version 0.90.2 - Copyright Jeremy Gordon 1998/2006 - JG@JGnet.co.uk
    Error!
    Line 1739 of Resource Script (bitmaps.RC):-
    Invalid accelerator event:-
    VK_C
    RES file not made
    Apr 2005
    Something tells me that when you exported the bitmap resources from ResHacker (into a .RC file) you must have selected more than just the bitmap resources.
    When you export, select ONLY the Bitmap icon on the left, and then Save Bitmap Resources...
    Just to verify, open the .RC file you currently have. Do you see more than just bitmap assignments in there?
    2002 Honda CR-V
    Maximum Bitrate Dalailama's Avatar
    Jan 2006
    Novara Italy
    ...cool trick!
    Cool trick Justintime!
    I'm just dealing with it...
    it makes easier everything!!!
    ...I was resizing iG icons and it works perfectly with photoshop batch actions!!!
    Live today like it is your last day, and behave as though you will live forever...
    my WEBSITE
    MapMonkey Dalai skin-preview-download ITA-email me for ENG
    Road Runner CrystalBlue skin-preview-beta release
    Apr 2005
    San Jose, CA
    Quote Originally Posted by justintime View Post
    yep you're right. Thanks
    May 2006
    If someone hacks the pc / car puter version to let it access the outlook address book, please show Inav how to do it too. Maybe they can make it their v5.0 release.
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    justintime u are my hero!!
    This is going to save me sooooooooooo much time.
    beer replenishment fund
    mp3car live search
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    It wouldn't have saved you (or me) any time if I didn't send ya the link to this thread! hahahah!!!!
    My Fiero Build Thread
