Results 1 to 10 of 10
Thread: Ruining multiple WinAmps?
    Apr 2001
    Queens, NY, USA
    My idea is having music on 3 rooms each with a separate LCD 4x40 and regular controls, next track/play/stop..........can this be done with on CPU? With 3 soundcards so that each winamp could use one??? what would I need? To have 3 rooms with deferent music playing but with the same Computer? can i run more then one Winamp at the same time? what about the LCD's? and the Keyboard.....as I'll need deferent controls on every room.....I'll buy separate cards and all but I would like one computer b/c I live in the city in an apartment so i'll do anything to save space and not make it bulky
    Under Construction Duron 750mhz, 256mb, Slow 40gb HD,
    8x Burner, Runing Windows XP Final. if this works out I'll get the same for the R/T
    01 Stratus R/T 200hp stock as hell
    88 Lincoln LSC 226hp with Alpine V12....at the rear Blaupunkt ODx694 sub box two 12 JBL's....front doors a pair in each Sony XS-F1621's.....more to come
    Aug 1999
    Upper Marlboro, MD 20772
    YES... study the winamp.ini file... i believe in there, there is a section for the soundcard or it might be in registry. Anyway start off with 2 sound card... create two dirs.... winamp1 & winamp2 and put the same winamp files in there... then get dir1 working and then dir2.....
    abcd-1
    Apr 2001
    Queens, NY, USA
    Yeah i know u can run Different Soundcards.......on the OutPut Settings.........but how can i run more then one Winamp?
    FLAC ppgt94's Avatar
    May 2001
    USA
    In prefrences, choose "Allow Multiply Instancese"
    Mar 2001
    Cincinnati, OH USA
    The only problem I see you having, is multiple LCDs. Most of them run off the LPT port, meaning you would have to have 3 LPT ports. In all you would need about 7 expansion slots (3 sound, 3 LPT, 1 video), better find a large motherboard! As far as controls you might want to look into some of the Winamp control plugins like Com-Port Control, Winamp Comm Control andComControl. They allow you to have 4 or more external buttons to control Winamp. I have made the hardware for these plugins and it is very easy!
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
    May 2000
    Ft Gordon, GA
    he could get serial lcds and a serial addition card, but i beleive it is hard to find software for them. havent really looked though
    "if everything is under control, you're not going fast enough!"
    Apr 2001
    Here, There, Everywhere
    i was gonna say a USB hub with multiple USB --> Parallel port adaptors, but I dont think they are that easy to program.....
    I think the 3 serial ports would be much nicer.....
    three sound cards, that would be fun!!! also make sure u have a fairly beefy CPU for 3X the mp3 decoding.....
    Project - GAME OVER :(
    Maximum Bitrate CrazyLittle's Avatar
    Jan 2002
    Oakland, CA
    USB parallel adapters are a no-no. The concensus was that because USB parallel adapters use software to run a printer, LCD's WON'T WORK because they require hardware access to the printer port.
    Multiple USB -> Serial adapters -would- work however. Only obsticle would be the cost of serial LCDs.
    Controlling said system would be a challenge too.
    Apr 2001
    yeah, thats what I assumed...... it would be nice if someone could just write a printer driver that you could pump data to it..... maybe using the 'plain text' printer driver....
    hrm.... might work..
    Apr 2001
    Queens, NY, USA
    So.........Now I've decided to only use in two rooms........the MotherBoard has 4 PCI's two ISA's,128mb ram,AMDK6-2 500mhz runing at 350mhz..........so i got the sound and the winamps.......but i still need 2 LCDS and a way to control these Winamps........Serial/USB/Parallel? what is cheaper and easier?........
    I'm already running a Puter for the alarm/plus my puter/my sis puter/and this MP3 puter........it would be nice to just use one for Mp3's around the house
