Page 10 of 30 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 297
Thread: EniCar the RR Clone
  1. #91
    Newbie nosoup4me's Avatar
    Aug 2006
    Fort Wayne, Indiana
    So this puzzled me why I drove around with my IG3 working in ENICAR and my gps receiver on and all worked. I went out again to my car just now and sure enough IG3 crashed at the start of ENICAR but ENICAR continued to load. Normally I load IG3 at start before my skin so when I go to nav the screen doesnt flash; so yesterday during testing, after everything booted, I closed my RR and launched ENICAR and it worked. This morning I tested this theory, after I found IG3 crashed from the launching of ENICAR... Iclosed ENICAR... launched IG3... then again launched ENICAR and it worked. I drove around the block and it tracked great.
  2. #92
    Jan 2006
    Montreal, QC, CA
    Yeah this is surely because of my way of launching IG. you can see that IG is hidden while loading, perhaps it does something that make it crash when it's totaly hidden. I have to check that.
    To bad because i was very proud of my IG loading at start without seen it.
  3. #93
    Aug 2006
    Fort Wayne, Indiana
    Yes, the way it currently loads is the bomb! You are definetly on the right track. It does seem to be related to having an actual connection to a receiver if that helps narrow down the problem. Also, the fact it crashes as soon as you set a destination.
  4. #94
    Jan 2006
    Montreal, QC, CA
    I'm still searching for a solution to the IG crash. I don't find why. tried 100 solutions got 100 crash. So stupid.
    PS you could try with the menu bar still on. Seems to not crash with. change your ini file. Or perhaps its because of my very bad reception in my home, who knows.
  5. #95
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by enitalp View Post
    It will crash everytime regardless. The only way is to disable the GPS. IGuidance crash right before ENICAR LOADS up. Try the com ports. Could be a problem with it trying to pick up the sat signals and then it crash. Beside that the programs is great. just need a little more work. If anyone can make there work like Nero Home that would be nice also. I think streetdeck is base on that
  6. #96
    Aug 2006
    Fort Wayne, Indiana
    when you launch IG3 and make sure it is running properly, then launch ENICAR you will get a com port error, but it runs ok after responding OK.
    are you trying to set the com port during launch?
  7. #97
    Jan 2006
    Montreal, QC, CA
    No i did nothing with com port.
    And i tried to put a delay at startup to make sure it's fully launched and i get the same result. I also tried to launch it later, when clicking on nav button, same result.
    tried to not remove the toolbar, menu, etc.. same result.
    etc....
  8. #98
    Jan 2006
    Montreal, QC, CA
    V0.04 is out.
    not a planned version but iguidance crash needed to be fixed.
    http://www.enitalp.com/EniCarV0.04.rar
    This is an update from V0.03
    What's new :
    - ESC Button Command working
    - MENU Button Command working
    - Support for page not matching skin size
    - Fix a crash in skin navigation
    Now Bongo skin works pretty well and surely some other using the same style of using command.
    - Indicator started.
    - Loading Indicator End
    - Fix IGuidance crash 1 day without any crash with gps module.
    NB indicator are loaded, react to clic but does nothing, this is just because it's a work in progress and the IG crash needed to be fixed.
  9. #99
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    Tell me what software you are you using (i will tell you who you are ) and i will have a look for embeding more software.
    Hello brave one, following to this topic I would probably say most of Europeans use different D3 front-ends (FreeDrive, MapMonkey, Meedio D3 plugin) since Destinator maps are probably most complete at the moment and there is (buggy but still documented) SDK available. Since Freedrive went "open source" too and its author is one of the most helpful and community sharuing guy in this forum, I believe most europeans would appreciate if you could (with help of Cdrskull probalbly) release a version of EinCar that would be built on top of D3 SDK directly.
    Would dou you say?
    Pretty please...
  10. #100
    Jan 2006
    Montreal, QC, CA
    Ok. After Finishing a few things i will go with destinator integration.
  1. REQUEST: Run Multiple RR instances
    By Jarrod in forum Road Runner
    Last Post: 12-21-2008, 08:54 AM
  2. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  3. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  4. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
