Page 4 of 30 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 297
Thread: EniCar the RR Clone
  1. #31
    Jan 2006
    Montreal, QC, CA
    Just checked and it seems that i have a memory leak. not good. the memory keep going up while in main menu doing nothing.
  2. #32
    Newbie nosoup4me's Avatar
    Aug 2006
    Fort Wayne, Indiana
    [QUOTE=enitalp;900610]Yes i will.
    I'm thinking since the begining off making a database for media, and update it at each launch of EniCar. Will be alble to have all the tag, but i'm still searching the best method to do it.
    QUOTE]
    "id3lib is an open-source, cross-platform software development library for reading, writing, and manipulating ID3v1 and ID3v2 tags. It is an on-going project whose primary goals are full compliance with the ID3v2 standard, portability across several platforms, and providing a powerful and feature-rich API with a highly stable and efficient implementation."
    http://id3lib.sourceforge.net/
    I do not know if this will help but It appears the code should be able to extraxt anything you want...including pics; which I am very interested in... most of my tunes are singles (not albums) and the album art is embedded.
  3. #33
    Variable Bitrate marazi's Avatar
    Dec 2005
    Skien, Norway
    great work...
    will there be full flash support...??
    cdr's latest skin freedom dont work... its flashed based...
  4. #34
    Newbie tcghost's Avatar
    Mar 2006
    FL
    Quote Originally Posted by enitalp View Post
    Yes i will.
    For memory i don't have a solution yet. this was not my main concern. As it's the maximum as all skin & bitmap are in memory after the startup, memory will not grow up. For the 80% i didn't check yet. but it's not normal. Just checked. and without playing a song widows sometimes says 47% when in audio_browser. and 0% when playing my song lol. I have to add my cpu usage. I think windows is going mad by the way i'm using it. It's my first development under windows. I'm used to xbox & ps2 lol.
    general slowness ? only on loading ? or in general ?
    I'm surprised and chocked.
    for xbmc good idea. i will check that.
    And for all thanks for the support.
    well, on startup, mostly... it takes around half a minute to load.
  5. #35
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    I knew i forget something before making my first showable version. Hope your not mad with this. I love your skin, use it in my car, that's why it was my guinea pig.
    Could i use it ?
    If not i will remove it from my EniCar distribution. Not planing to distribute it with EniCar, it was just because of the first version got a limit support of other skin.
    Sorry about that.
    not a problem at all.. :-) watching your work... will be doing some tests later on just how fast flash can be with our FE :-)
    CdR
  6. #36
    Jan 2006
    Montreal, QC, CA
    Quote Originally Posted by marazi View Post
    great work...
    Yes flash will be fully supported. For the instant i only support command comming from flash, i don't send anything to flash (skinner will understand).
    Hope to do that soon.
    Quote Originally Posted by tcghost View Post
    half a minute ? i think you are the winner of the slowest skin loading
    Ok i cheat a little as i have two Raptor 10000tr/min in raid. but on mc2.0 skin i'm at 4/5 secs not 30 !
  7. #37
    Jan 2006
    Montreal, QC, CA
    Quote Originally Posted by CdRsKuLL View Post
    CdR
    I hope flash will be fast. For the instant i only take command from flash and don' t send any label to it. soon. And i need to get ride of a stupid white flashing things when i hide the flash control when changing page . Windows can be stupid sometimes.
    When you hide a CWnd or move it, it does it immediatly, and paint a white square at the position of the window. Made some test with two screen (i have a lilliput touchscreen as my secondary display on my work computer), so i'm able to step by step the process without other window interfering in EniCar window. And instead of sending a paint message windows directly paint white square. So i need to deferred the window/move close myself. during the paint.
  8. #38
    Mar 2006
    FL
    I was running it on my dual core laptop with 1 gb of ram too... :-/
    does it read through the music and video directories at startup? cause I have more than 100 gb of files in those directories
  9. #39
    Jan 2006
    Montreal, QC, CA
    Yes at startup i parse the media directory to memorize the directory tree. No operation on the file.
    For me the execution of this part of code is less than 0.1s, and i'm in slow debug mode.
    for mp3 dir = 5.5go 660 files
    video dir = 4.6go 115 files.
    not that much file but it's very fast. no reason to be slow.
    it must be the skin loading. In the next version i will add a splash screen with operation in progress before showing the menu. and i will log all in a log file. That way i could see the crashing problem, and the speed problem at loading.
  10. #40
    Jan 2006
    Montreal, QC, CA
    Ok, i've made a patch to the version 0.02
    added some log info before the main menu showing. So i could check the slow problem.
    I don't want to let this problem here, peharps there is a huge problem and it must be resolve now.
    this is the new version of the version 0.02. new exe to replace the old one.
    After reaching the main page you should have a enicar.log in the enicar directory. post me the result.
    http://www.enitalp.com/EniCarV0.02.rar
    here is mine : The time is in second since the start. the precision in the millisecond.
    EniCar started
    0.000 Start Register Command
    0.000 End Register Command
    0.000 Start Reader init
    0.000 End Reader init
    0.000 Start Read enicar.ini
    0.000 End Read enicar.ini
    0.000 Start Cache Media
    0.000 Start cache subdir mp3
    0.015 End cache subdir mp3
    0.015 Start cache subdir video
    0.031 End cache subdir video
    0.031 Start sort mp3
    0.031 End sort mp3
    0.031 Start sort video
    0.031 End sort video
    0.031 End Cache Media
    0.031 Start Video Window
    0.031 End Video Window
    0.031 Start Mplayer init
    0.047 End Mplayer init
    0.047 Start loading skin
    0.047 load general.ini
    0.062 start finding *.skin
    0.062 end finding *.skin
    0.062 Start Loading skin Page :
    0.062 c:\src\enicar\skin\MC2.0\audio_browser.skin
    0.203 End Loading skin page
    0.203 Start Loading skin Page :
    0.203 c:\src\enicar\skin\MC2.0\audio_browser1.skin
    0.328 End Loading skin page
    0.328 Start Loading skin Page :
    0.328 c:\src\enicar\skin\MC2.0\Audio_Player.skin
    0.687 End Loading skin page
    0.687 Start Loading skin Page :
    0.687 c:\src\enicar\skin\MC2.0\exit_menu.skin
    0.765 End Loading skin page
    0.765 Start Loading skin Page :
    0.765 c:\src\enicar\skin\MC2.0\EXTERNAL_GPS.skin
    0.843 End Loading skin page
    0.843 Start Loading skin Page :
    0.843 c:\src\enicar\skin\MC2.0\game.skin
    1.000 End Loading skin page
    1.000 Start Loading skin Page :
    1.000 c:\src\enicar\skin\MC2.0\games.skin
    1.093 End Loading skin page
    1.093 Start Loading skin Page :
    1.093 c:\src\enicar\skin\MC2.0\LAUNCH.skin
    1.187 End Loading skin page
    1.187 Start Loading skin Page :
    1.187 c:\src\enicar\skin\MC2.0\menu.skin
    1.328 End Loading skin page
    1.328 Start Loading skin Page :
    1.328 c:\src\enicar\skin\MC2.0\mixer.skin
    1.437 End Loading skin page
    1.437 Start Loading skin Page :
    1.437 c:\src\enicar\skin\MC2.0\NUMOSK.skin
    1.515 End Loading skin page
    1.515 Start Loading skin Page :
    1.515 c:\src\enicar\skin\MC2.0\obd.skin
    1.562 End Loading skin page
    1.562 Start Loading skin Page :
    1.562 c:\src\enicar\skin\MC2.0\OSK.skin
    1.687 End Loading skin page
    1.687 Start Loading skin Page :
    1.687 c:\src\enicar\skin\MC2.0\RADIO_MENU_FUNCTION.skin
    1.765 End Loading skin page
    1.765 Start Loading skin Page :
    1.765 c:\src\enicar\skin\MC2.0\Radio_Player.skin
    1.890 End Loading skin page
    1.890 Start Loading skin Page :
    1.890 c:\src\enicar\skin\MC2.0\skin_browser.skin
    2.000 End Loading skin page
    2.000 Start Loading skin Page :
    2.000 c:\src\enicar\skin\MC2.0\status.skin
    2.109 End Loading skin page
    2.109 Start Loading skin Page :
    2.109 c:\src\enicar\skin\MC2.0\tv.skin
    2.203 End Loading skin page
    2.203 Start Loading skin Page :
    2.203 c:\src\enicar\skin\MC2.0\video_browser.skin
    2.328 End Loading skin page
    2.328 Start Loading skin Page :
    2.328 c:\src\enicar\skin\MC2.0\video_player.skin
    2.453 End Loading skin page
    2.453 Start Loading skin Page :
    2.453 c:\src\enicar\skin\MC2.0\wbrowser.skin
    2.547 End Loading skin page
    2.547 Start Loading skin Page :
    2.547 c:\src\enicar\skin\MC2.0\weather.skin
    2.656 End Loading skin page
    2.656 Start Loading skin Page :
    2.656 c:\src\enicar\skin\MC2.0\weather_detail.skin
    2.781 End Loading skin page
    2.781 End loading skin
  1. REQUEST: Run Multiple RR instances
    By Jarrod in forum Road Runner
    Last Post: 12-21-2008, 08:54 AM
  2. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  3. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  4. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
