I got through, so here you go LS... copied from main page at Sourceforge
IMPORTANT
The release v0.3.1 has a minor bug. If your on a Windows machine, please put JDash at the root of your C: drive. (c:\jdash). On linux, pleasemake sure the directory path doesn't have any spaces in it. Or.. go download the patched version v0.3.2.
Welcome to JDash.sourceforge.net
JDash is an open source project giving people a visual dashboard of their cars sensors.
JDash is still under development, so please be patient,and check back often.
Release Change Log
Look in the Current events
Current Features
Future Features
- Complete Graphical visual interface to your cars ECU
- Written in 100% Java
- Runs on Linux / Windows and should work on a Mac
- Supports Subaru Select Protocol (SSP) on the Tactrix cable
- 100% Skinnable interface
- Customizable ECU value mappings
- Modify the output of a sensor value with a simple "BeanShell" script. No need to write code.
- Customizable Analog Gauges with High / Low indicators
- Customizable Digital Gauges
- Customizable LED Gauges with High / Low Indicators
- High / Low gauge needles with reset buttons
- Data Logging to a Database
- Data Log Playback
- GPL Open Source
- Very Modular Design allowing easy customization of Skins and ECU Monitors though changing of config files.
Software Requirements
- Support for ELM OBD-II module (Anybody want to help with this one)
- Event driven sounds
- Automatic Installer
- Data Log extraction to CSV
- ECU Config Files for as many different ECUs as possible
- Skins, skins... and more skins. I'm not an artist, and I'll need help with the skins.
Harware Requirements
- Windows or Linux OS
- Sun Java JRE 1.5 and greater (1.4 is not supported)
- Display Check Engine Light Codes
- Reset Check Engine Light
- Reset ECU
- Your Car
- PC / Laptop
- [Tactrix http://www.tactrix.com/] SSP interface cable linked to a serial port (or similar)
LinkBack URL
About LinkBacks
