Page 11 of 11 FirstFirst ... 234567891011
Results 101 to 108 of 108
Thread: ShutControl - Laptop Shutdown Controller Software
  1. #101
    Jul 2009
    Quote Originally Posted by S_K_U_N_X View Post
    it monitors the button, my battery drivers are broken at the moment and it still works. Its a free app, why not check it out?
    I did and it didnt work ) mind u I am running Win7
    I press the power button and the PC shutdown it did not invoke the pre and post hibernate scripts or reboot the PC instead of shutting down
  2. #102
    Apr 2002
    orlando
    I think I was a bit confused, and believe your correct in thinking this wont work for you.
    Ask this guy if he figured it out
    http://www.mp3car.com/vbulletin/powe...er-button.html
    UMPC built in to dash.
    Winamp, game emulators, Touchpad built in to car, DVD player built in to dash, GPS gamrmin moble pc. IR remote for use of a remote control. ps2 supper mini keyboard for when needed.
  3. #103
    Newbie n3w813's Avatar
    Apr 2007
    CA
    I installed this app and the standby timer is working great. But I'm having trouble getting the pre hibernate/standy commands to execute. I left the 'apps before hibernate delay' default at 10s, and the command (opening notepad) delay at 5s. I set the hibernate timer at 600s.
    After I go on battery mode, the timer counts down from 600 seconds correctly, but never executes the command and open notepad and just hibernates after 600s has passed. If I manually press the launch pre hibernate button on the gui, notepad launches correctly?
    Anyone having issues getting the prehibernate commands to work?
    BTW, I'm using win7 32bit and single action mode in ShutControl.
    Lexus IS250 CarPC Project
    Plan [++++++++++] 100%
    Buy [++++++++++] 100%
    Config [+++++++++-] 90%
    Install [++++++++++] 100%
  4. #104
    Mar 2010
    I ran into a problem today when installing ShutControl. I know its not common, but some people don't have their boot drive as C:\.. for some odd reason when i installed xp this time it set it as E:\.. not thinking of it being that big of a deal I continued to install the rest of my software until it came time to install ShutControl, which appears to be hard coded to install some files on C:\ even if the extract folder is set to somewhere else.
    Is it possible for you to change that? I did find a work around temporarily by setting up a virtual drive redirect..
    edit: Actually scrap that request. The Author hasn't updated the first post since 2007 so I doubt he will now..
  5. #105
    Dec 2007
    Quote Originally Posted by millermil121 View Post
    The config file getting corrupted is the biggest issue for me. Everything else I have found work a rounds for.
    I had this too, so I ended up writing my own script in Windows Powershell.
  6. #106
    Jun 2006
    Actually, I'm still about! I check this thread once per year.
    I'll have a look through the posts and see if there's anything worth fixing
    '98 Peugeot 306
    Project Status: I sold it ages ago!
    ShutControl
    The ultimate shutdown control software for laptops.
  7. #107
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Quote Originally Posted by blessani View Post
    I know it might be a while till you check this thread again Blessani, but it would be cool if you could adjust the software to not be hard coded to Drive C, which it seems to be
    Thanks.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  8. #108
    Mar 2006
    First off let me say that this program is EXACTLY what I was looking for. I haven't installed it yet, but I read through all 11 pages of this thread and have high hopes for it.
    One thing I want to mention/ask is....for the WOL circuit. Is the 12v regulated? Or are you just grabbing power directly from the battery?
    As you all probably know, an auto electrical environment is very noisy. Also, the vehicles voltage is not really 12v. A fully charged battery is 12.6v. An alternator normally supplies 14.4v. Mine sits at 13.8v because I installed an AGM battery into my car. (I had to program and register my battery into my car using corporate level software.) Anyway, I would recommend everyone to add a 12v regulator and a 100uF decoupling capacitor to regulate the batteries input voltage to 12v (obviously) and to absorb some of the transient voltage spikes.
    Thanks again for the program! Awesome work!
  1. New shutdown controller - software
    By weekendowel in forum Power Supplies
    Last Post: 05-06-2009, 08:07 AM
  2. Shutdown controller - New Version
    Last Post: 06-10-2004, 01:28 AM
  3. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 02:33 PM
  4. Cold shutdown controller!
    By phil.45 in forum Power Supplies
    Last Post: 01-13-2003, 10:46 AM
  5. software for mp3ondemand shutdown controller!
    By mykolJay in forum Software & Software Development
    Last Post: 07-08-2002, 04:17 PM
