Page 6 of 11 FirstFirst 1234567891011 LastLast
Results 51 to 60 of 106
Thread: ShutControl - Laptop Shutdown Controller Software
  1. #51
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by andyman View Post
    I'm confused.
    If this is a failsafe if windows locks up then what allows the software to work since it is running on the same windows machine?
    Is it lockup proof?
    Thanks for any feedback!
    In simple terms this software just monitors your power to your laptop, then when it detects the power has been switched off (ie taking the key from ignition) it will do what you have programmed for example
    shutdown, hibernate, restart
    in essence for the laptop user this is a software shutdown controller, you just get outta your car, and the computer just uses the laptop battery while it performs the shutdown or woteva you set...
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #52
    Nov 2006
    Wales, UK
    If anyone makes use of the post and pre shutdown program launcher is there a way of altering how the programs run eg: when i load a macromedia flash .exe file on resume it runs in a very small window, and it appears this software has cut off the top menu so its not possible to close it either
    Maybe a parameter im missing some where...?
    If anyones interested im also startin to test this using Decon to disable hardware, and renable it after machine comes out of hibernation, will post the results handy if you have problems with touch screen not working on resume which is a pain in the A**.
    CarPuter Progress:
  3. #53
    Jun 2006
    @jonessc
    I can't think why it would affect the way the application launches. Basically, it only calls a launch external app function, nothing too fancy. If you want to send through your flash app, I can run a couple of tests and see where its going wrong.
    @mukow
    Well it kind of defies the point of the software to want to use it on batteries, but I could maybe script in a "pause" button for you, but I can't think of a way to have it pause itself, as it would compromise the way the software worked.
    Glad your all happy with it, again, any direct feature requests and I can add them in, drop me an email @ benlessani atat hotmail dotdot com.
    '98 Peugeot 306
    Project Status: I sold it ages ago!
    ShutControl
    The ultimate shutdown control software for laptops.
  4. #54
    Variable Bitrate kelmk's Avatar
    Aug 2007
    SF
    How can I use this to close down some apps before hibernating?
    I would like to close them nicely and not just kill them.
  5. #55
    Nov 2006
    Wales, UK
    Quote Originally Posted by kelmk View Post
    Quote Originally Posted by blessani View Post
    @jonessc
    Thanks sorted now, im now longer using flash!
    Just a quick question tho, is it possible to close applications on hibernate, and reopen at startup?
    Other than that this software has been pretty solid!
    CarPuter Progress:
  6. #56
    Aug 2007
    SF
    I can't get the pre shutdown apps to run.
  7. #57
    Sep 2007
    Same here.
    /Edit ->
    Alright I've got it now. The selection of standby/hibernate/shutdown is the issue. When selecting shutdown it does not run any applications. Can this be fixed?
    As a bribe I'm sending a donation with the request.
    Update: I put my money where my needs are.
    Paypal Donation Confirmation Number: 0W3594373F1888009 Placed on Mar. 21, 2008
    Donation amount £10.00 GBP (about 20 bucks US)
    Purpose:
    Bribery to fix shutcontrol to run apps when shutdown is selected instead of just hibernate.
  8. #58
    Aug 2007
    SF
    It doesn't run apps on standby either.
    I have a bigger problem though. I have to constantly reinstall this program anytime I have to force my computer to shutdown. After I reboot Shutdown control won't run anymore. Just an exception error on startup. I reinstall and everything is good again.
  9. #59
    Aug 2007
    SF
  10. #60
    Sep 2007
    Well...
    Well no word from the ShutControl maker, Sent a donation of 20 bucks and no response. Also sent an email to the one on record through paypal and this site...
    Looks like it's becomming abandonware now. Anybody have an alternative solution. This program has the perfect idea just a couple bugs in the implementation and if anybody has the code or knows how to reach the author, please speak up. It's almost there as THE solution for a lot of people using laptop computers and there will only be more in the future looking for something like this.
  1. New shutdown controller - software
    By weekendowel in forum Power Supplies
    Last Post: 05-06-2009, 08:07 AM
  2. Shutdown controller - New Version
    Last Post: 06-10-2004, 01:28 AM
  3. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 02:33 PM
  4. Cold shutdown controller!
    By phil.45 in forum Power Supplies
    Last Post: 01-13-2003, 10:46 AM
  5. software for mp3ondemand shutdown controller!
    By mykolJay in forum Software & Software Development
    Last Post: 07-08-2002, 04:17 PM
