easy ones here..... im sure a bit more searching would have found em...
1. unless you installed winamp in the root directory of "c:\program files", that execution will not work... it should read
"shell=c:\program files\winamp\winamp.exe" also you may wanna replace "program files" with the DOS equilivent (usually "progra~1")
2. this has been covered, and should work. could it be your remote plug-in needs a full path the the exe? it would not supprise me in the slighetest.... so try "c:\windows\rundll.exe....." you get the idea.
3. 98 works fine for me... but give 98lite a shot to 'trim the fat'...
LinkBack URL
About LinkBacks
