Results 1 to 10 of 14
Thread: minlongon file is 491 kb? Is windows replacing it?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Hi.
    Ok, I tried the method to replace winlogon with minlogon. I first turned off windows file protection via the registry. Then, I renamed winlogon.exe to winlogon.exe.bak. I quicky copy minlogon.exe to the system32 folder and rename it to winlogon.exe. I then run the required registry entry. At first, minlogon (renamed to winlogon) is 17 kb. However, after a few seconds, I see that my new file changes to 491 kb and is the exact size as the original winlogon. Is windows changing this file? Have I sucessfully applied the minlogon mod or is windows just replacing the file, rendering my mod attempt useless? Your advice would be appreciated. Thanks.
    Ps. I just read that ctrl , alt ,del doesnt work after the minlogon mod. In my case, ctrl, alt, del still works. I am guessing I didnt correctly apply the minlogon mod?
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by nobb View Post
    Hi.
    CTRL, ALT, DEL work if you have a program call CAD. But yes you haven't set up minlogin correctly if you can still CTRL, ALT, DEL
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    windows is replacing the file...
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Ok thanks for everyone's help but I managed to fix my problem. I installed 2fastXP then applied the minlogon tweak after. I am actually VERY surprised. Before, my boot times were 1 min +. Now I can get music playing at 30 seconds.
    Jun 2006
    Richmond VA
    Sorry to bring up an old thread, but i'm having this same problem where windows recreates the winlogon.exe file. I have tried disabling windows file protection, but no luck. How can i fix this?
    Thanks,
    Brett
    May 2004
    Michigan
    Brett, I'm also having the same problem. Whatever I try just won't work. I've tried the whole copy, paste, rename thing, but it doesn't seem to work. I found a thread saying to boot into the windows recovery console to rename the files, but all that did was not allow me to get into windows, and the computer just kept restarting.
    Has anyone else experienced this? Or, any ideas on how to fix it?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Just a word of advice. Although I dont use the minilogon tweak anymore, I HAVE had my windows install corupt by not applying the tweak properly. I dont remember exactly, but it was something small. I had to do a complete format and reinstall. So just a word of warning...follow the minilogon steps EXACTLY and be careful.
    May 2004
    Michigan
    I'm using XP pro, and I think my problem has to do with not disabling windows file protection the right way. Anyone have an idea how?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Yea I definately think you should disable file protection. The file you are replacing is a system file.
    May 2004
    Michigan
    I've tried to disable it, but it doesn't seem to work...is there something special I have to do to disable it in XP pro?
  1. New EWF + MinLogon and CF instructions
    By SFiorito in forum WinNT Based
    Last Post: 03-12-2010, 02:39 PM
  2. Anyway to force windows to always boot from hibernation file?
    By adamis in forum General Hardware Discussion
    Last Post: 12-28-2003, 10:49 PM
  3. Windows ME logo.sys file
    By Bj in forum Software & Software Development
    Last Post: 05-07-2001, 10:51 PM
  4. file corruption with windows?
    By Squeezer in forum Software & Software Development
    Last Post: 02-07-2001, 07:45 PM
  5. changing font size of file names in Windows Explorer?
    By Squeezer in forum General Hardware Discussion
    Last Post: 01-11-2001, 05:49 PM
