Results 1 to 10 of 10
Thread: Winamp LCD display plugin / IRMan plugin - together?
    Maximum Bitrate Jarrod's Avatar
    Jan 2002
    Melb, Australia.
    I am using a 40x4 character LCD module in my setup and I am having trouble configuring the winamp plugins to work together for the LCD display and IRMan input.
    I want to be able to access the menu system in the lcd plugin by using my remote and IRMan plugin.
    The way my menu comes up on the LCD is by pressing the 'M' key on the keyboard, now I had an IRMan plugin that supposebly allowed you to set buttons on the remote to keyboard keys. I tried to make one of the buttons use the 'M' key, but it never worked.
    Now I am using another IRMan plugin, and I don't think this one allows me to set buttons on a remote as keys. I have everything else working except this, so I can use the remote to control my music and the LCD plugin displays the info correctly, but I just cant get this menu thing sorted out.
    The plugins I am currently using are as follows:
    LCD plugin - http://www.markuszehnder.ch/projects/lcdplugin/
    IRMan plugin - http://www.evation.com/software/winamp.html
    Is there a better IRMan plugin out there that has all the features the one im currently using, plus a custom key ability?
    Jarrod - Holden VX S!
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    www.girder.nl + the igor56 hardware pluggin on their site. try this instead of the irman plugins, lets you do anything you could do with a keyboard with a remote.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    FLAC Mastero's Avatar
    Aug 2001
    India
    go to my website in the software page you will find your solution
    DRCR .....
    best for keyboard replice
    Mastero
    Mar 2001
    Cincinnati, OH USA
    There is also IRAssistant.
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
    Jan 2002
    Melb, Australia.
    Thanks for all the suggestions guys, I will give them a go and tell you how it ends up.
    Jan 2002
    Melb, Australia.
    girder, help anyone?
    I tried using Girder to send the 'm' keypress command to winamp, but it didn't work. Any help on how to get this to work would be great!
    Jan 2002
    Chicagoland, IL
    You are setting the target of the action as the winamp main window, right? and F5 will test an action, with out the required ir device, so you can see if the action is not right, or girder didnt capture the signal from your remote correctly.
    -Nick
    Jan 2002
    Melb, Australia.
    Everything I have tried is correct. I tried that F5 thing, still no go. I also tried to use the capture method, it catches when i press 'X' for example (play i think it is) but not 'M' or any other keys that arent defined by winamp to begin with.
    I noticed another guy at the girder.nl forums was having the exact same problem as me, so maybe the plugins just aren't compatible.
    Any thoughts?
    Jan 2002
    Chicagoland, IL
    You're not using the keyboard plugin and capturing the m to a command are you? You should be defineing the output of the command on the tabs, windows/os/command/girder/mouse/keyboard/plugins. pick the keyboard tab and the key (m in this case) should be the sentance.
    -Nick
    Jan 2002
    Melb, Australia.
    thats the exact way im doin it, NOT using the keyboard plugin.
