Results 1 to 10 of 11
Thread: Winamp shuffle algorithm
    Constant Bitrate jeffreyd_tx's Avatar
    Sep 2006
    Wilkes-Barre, Pennsylvania, United States
    Question Winamp shuffle algorithm
    Is it just me or does Winamp play the same songs and artists over and over again. I have adjusted some of the settings within winamp but it does not seem to make a difference. I have a modest collection of about 3000 songs and I seem to be hearing about 100 in random order while every once in awhile I will get a treat.
    All of my songs are added to the winamp library and loaded to a playlist.
    FLAC evandude's Avatar
    Mar 2005
    Maine
    What version of winamp are you using? AFAIK, the 2.xx versions do something like creating a random (shuffled) playlist once, and then playing that same playlist every time, and the newer (5.xx?) versions have an "actual" random function where they randomize it on-the-fly. I've been using 2.xx because I couldn't get the vis from 5.xx to embed properly, and I have the same issue with random play.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Sep 2006
    If that were the case, winamp wouldn't play the same song until it reached the end of the list. I am intersted whether others have the same problem or a solution.
    Variable Bitrate gameboy's Avatar
    May 2005
    Elizabeth City, NC
    i've got the same problem with winamp...some times, it even plays the same song twice in a row
    95 Mazda Protege LX
    Worklog
    Overall [Project Dead] 0%
    2003 Nissan Altima
    [XXXXXXXX--] 80% Planning
    [XX--------] 20% FABRICATION/INSTALLATION
    Worklog
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by evandude View Post
    when using winamp 5 you have to set the skin to classic mode and not modern skins to get the vis window to embed properly. Thats assuming that you are using Road Runner as your front end.
    beer replenishment fund
    mp3car live search
    Constant Bitrate soundoff's Avatar
    Jul 2004
    AUSTRALIA
    i ran winamp 2.95 for years in my car - the random sucked.
    i now run 5.x random is actually random
    Nov 2006
    United Kingdom
    Just a thought but if winamp doesn't close properley it wont save the settings. Sounds odd tho. My one runs perfectley and seems to shuffle without fail.
    Let us know what happens!
    Come on Peugeot....I want to fill you with noise!
    Sep 2006
    Quote Originally Posted by sheepy View Post
    Shuffle "works". Just not very random with a subset of of entire playlist played.
    You know, I wonder if the older versions have a limitation on how effectively they can manage a playlist. For example, winamp will manage a playlist of 500 songs very well but beyond that, it can't keep track of what it has played so it grabs repeats. I still need to try 5.13 to see if that makes it better.
    Dec 2008
    Cool less than 500
    Hi all,
    One of you mentioned that random seems to work when you have less than 500 songs. I don't think this is true. When I was still using the older version of winamp, I had a playlist of less than 500 songs, and I still seemed to hear the same set few all the time; once in a while I would get a different song. When I looked through my songs, I realised that there were some I almost never heard and a set bunch that I almost always heard.
    A friend of mine said that the more often a song is played the more likely the randomizer is to pick it making for a perpetuating cycle of those previously played being more likely to play again. Not sure this would be the only factor, however, since otherwise it would seem that one song should stand out among them all as the most commonly played, rather than a set few.
    Anyways...I agree - the newer version does seem to randomize much better. I have a playlist now of over six thousand songs, and it seems to randomize just fine.
    ~smoogs~
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    Edmond, Ok
    so its sounding like the randomization issue is solved by updating to the 5.xx version of winamp. i was going to look more into fixing that randomization issue, then i saw this. sweet! i usually used to set my playlist to random.
  1. Replies: 3
    Last Post: 11-23-2006, 11:14 AM
  2. Replies: 8
    Last Post: 08-01-2006, 03:51 PM
  3. daamnn winamp...shuffle...
    By Danielealleli in forum Software & Software Development
    Last Post: 07-02-2006, 03:40 PM
  4. Winamp IBusComM.ini settings finally working
    By intense in forum Software & Software Development
    Last Post: 08-23-2005, 01:07 AM
  5. Winamp True Shuffle ?
    By Axkicker in forum Software & Software Development
    Last Post: 08-11-2000, 09:59 AM
