Results 1 to 6 of 6
Thread: the command line -init
    Low Bitrate DAMBRO24's Avatar
    Oct 2005
    who can explain to me how to write this...."-init" asa parameter in the command line of windows? the command line is where it says run correct?
    im trying to get the set com port option up on phonecontrol.net
    please help me , tis is what is says to to:
    "start the aplllication from the command line and apply the "-init" parameter". I would i just do not know what this means .
    thank you
    Elsewhere
    Modify the shortcut....
    Add the command line parameter tot he end of the command line.
    How about the Wiki?
    Oct 2005
    Quote Originally Posted by DarquePervert View Post
    i did that it says it cannot be opened that way .
    do i have to do it at the entire end . because i did
    Oct 2005
    i do not understand it should be working if that is all i have to do.
    Oct 2005
    what am i doing wrong , there has to be a way to bring up the initial com port setttings , i saw them the first time and then they never came up again
  1. Invalid Argument
    By tn6478 in forum StreetDeck
    Last Post: 12-30-2007, 09:02 PM
  2. Bus Init Error
    By BarryC in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-03-2007, 07:35 PM
  3. 1.0.4.7 bug
    By debugger in forum StreetDeck
    Last Post: 07-01-2006, 04:01 AM
  4. Hotkeys Init Error
    By wizz in forum MM Bugs
    Last Post: 05-23-2005, 06:03 PM
  5. Girder: Plugin loaded but hardware init failed.
    By jol in forum Input Devices
    Last Post: 02-22-2003, 06:25 PM
