I took some of the XM Code in RR, and Turned it into an ActiveX control, I dont know Delphi, but if you can use an active x control then you should be able to use this from your app. if you would like I can post it, code and all. It is just the same as Road Runners XM Code Just Slightly and I mean Slightly modified. So if you want this let me know, Oh and since this is Code from RR, you can not use it for comercial sale unless you get an ok from Guino
cheers
LinkBack URL
About LinkBacks
