I wonder how exec would behave if the exponential mode is on, and it the driver is sending something like this:
exec.exe FAST_FORWARD (or whatever the command is)
at 200Hz!![]()
simple for me is no good, it's got to be hard
what would you need a front end for?
regarding the mechanism for switching contexts, I was thinking it would be better if the frontend somehow told the driver which context it should be in. I'm sure we can think of a few mechanisms to do this. That way, if the touchscreen is used to switch to a different screen, the context would also be switched.
Current:
[BMW E46 ///M3 Convertible]
Previous:
[BMW E31 850CSi]|[BMW E39 535i]|[BMW HVAC Research]|[IBUS Scrolling Text]|[BMPuter]|[Velocity]|[TomTom]|[Vision]|[Space Navigator Driver]|[Super Fast Boot]
at 200Hz!![]()
Current:
Previous:
Well, with the keymapping, you define what action you want to take on what skin page, or it can be universal for all skin pages, or it can have certain functions for certain skin pages, and then one default action for the rest.. I'm going to try to dig up that thread again. Why add in extra complexity when RR already features mechanisms for this
as for the front end, it woul dbe great to just do a gesture, and have the lil app figure timings and such...
this isnt THE thread i read, but it pretty much explains it..
Context Sensitive Hotkeys? (PowerMate related)
Ah, I see what you're saying now. That's a good idea, I'll get it to spit out keys too so that can be used. In that case, you'd only define one context.
Might still be worth including multiple contexts for other FE's. I wonder how many other front ends do this, if at all. Any idea anyone?
Current:
Previous:
Cool![]()
Yea i guess for other front ends it would be helpful to have the front end tell the driver what part of the skin it was on.. But i mean really, who uses other frontends?
Cant wait for this to be releasedglovepie was great to play with the sapce nav in RR but a native driver will be 1000x better
I think being able fine tune it is a good option for sure & I think gestures are a great idea, for example all the way up followed by an all the way down can trigger a predefined action I guess, but since this thing is so sensitive & doesn't have a very solid center return, what are the chances of performing gestures accidentally? I think it might be good if gestures required a full travel one direction then another, so it would be very unlikely for a false gesture...
also, it would be cool if gestures could be used with more than just 2 successive inputs, like for a control-alt-delete, could require an up/down/up/down for example...
I could see this getting pretty complicated to use if many gestures are implemented, but that just means more control for those who want it, & for those who want to keep it more simple, then gestures can be limited...
I'm not sure I understand how this can be function changed depending on the screen it's in, but if that can be done in RR it would be awesome... I guess this is one of the advantages of writing your own program?
I have used the shuttle express which reminds me of this thing... one way it does progressive travel is through key presses, but the further through the axis the control is, the faster it repeats the key press, so a slight twist would press for a volume up say once every half second, & the further through the travel the faster they would repeat.... everything was set with a program that gave a nice user interface & had the ability to save different profiles... it could do different actions depending on the program it was used in, but nothing like changing functions depending on the screen.... I'm guessing this is going to be a matter of doing this only in roadrunner?
wish I knew a bit about programming to be of more help... I am ordering one of these now finally![]()
Per your PM request.
I think if possible, you should try to strickly follow the standard ini format of Section, Key, Value
[SECTION]
key=value
There a few reason why i say this, one it being easier to read/edit and also more importantly easier for an external application to read and edit.
I can whip up an autoit script that would read and set all the values and also intergrate this into RR with nice graphics to visualy see what you are editing.
Others can do the same for there frontend also, or even make a stand alone app to do the same.
It looks like your using xml now, but in either case i dont think you should create a format but yet use an existing format.
Where the section would be the name of the context
[CONTEXT GLOBAL]
and the keys names specifly what you are editing
AXIS_PAN_X=binary, 0.1
ACTIONS_CONTEXT_SWITCH_UP=BUTTON_R
note i reversed the way it original was so the value is always on the right of the = sign
and also removed the [AXIS] section and put it as a prefix to the key
This way there aren't any duplicate section names that will confuse any .ini editor or external app that tries to read the file as to where to read/write data.
So everything that is under a specific context applies to that context until it reaches another context.
I see the CONTEXT_SWITCH action but im unsure of how this exactly would work.
Do i state what context i want to switch too?
like
CONTEXT_SWITCH=GPS
if so where would i state the gesture or button that activates this switch?
I have a few ideas on how the context switching should be done.
1. Manual switch where the context_switch would be tied to a specific button or gesture and overrides any other setting for that button or gesture.
When activated it would cycle to the next CONTEXT in the configfile, top to bottom in the order they are listed.
This could get click happy though and require multiple button presses to get to the context you want.
2. Another way would be for the app to look for window titles to determine what context it should be in.
I belive this is the best method but would require more work than the first.
So if i wanted to have my GPS context to only work if my gps application is in "focus" and not just found. It may look like this
[CONTEXT_GPS]iguidance
where "iguidance" is the apps window title
3. Another way would be for the app to accept command line switches that would switch the context.
So if im using my favorite frontend , Road Runner, i could have it send a command to the driver app to switch to the GPS context when i enter the gps screen and another command to switch back when i leave.
"RUN;driverapp.exe|CONTEXT_SWITCH GPS"
This would require a little bit of work for skinners, but i personally dont mind, others may balk at the extra work.
Im a little confused about what BINARY and PULSE modes are, and the difference between them.
I think, binary is a simple send key or action that happens once where pulse is kind of like a repeat mode? So If i have the letter K tied to a action with pulse it would send the letter K over and over until i stop the action?
in any case, whatever you decide to go with, the end result is the only thing that really matters.
Looking at the file, it seems the end result is what I would like, so if i had to sit and edit the config file in its current state i wouldn't mind at all.
Its not confuseing to me or anything, i just know i wouldn't be able to write a frontend to the configfile.
But in practice, once you get everything setup the way you like, you rarely if ever will touch the file again.
My biggest question that im still a little wondering about would be exactly how the context switching happens.
Ill post more if i come up with any ideas or questions.
beer replenishment fund
mp3car live search
First of all, thank you all for your valuable input. It's much appreciated.
Yep, the threshold value is the amount to ignore before that axis kicks in. So the higher you set that value, the more you'll have to push/pull that axis to perform that action
They can be. You'd define it something like:
GESTURE: TWIST+ | 100 | TWIST- | 100 | VERTICAL+ | 100 | VERTICAL- | 100 | ...
Which is a bit like a mortal combat special move... but there you go
Tha's the idea, yep. The mechanisms to do this are something that I'm hoping to figure out in these discussions.
To begin with, I would imagine so, but having read what liquid_smoke has said below about doing it based on active window, this may not be the case.
at last
Good call. I did try a hybrid ini/xml format, so that I could gain structure and readability. I find that ini files are nicer to read than xml, but xml provides structure. You're right though about other programs using it, and that outweights the value of the structure element. Using prefixes for organsation as you've mentioned is the way to go.
The idea I had there was that using a button would cycle through the gestures top to bottom. but then I wasn't sure how the user would keep track of the context they're currently in. I then thought that a mechanism is required to inform the user, like perhaps an overlay bit of text.
exactly, especially when done blind. unless notification is there also, then I would say this is a no-go.
Interesting approch and I like it. However what of contexts that do not have an app window title? I mean, skins within RR say that do not embed an app? Does RR change it's title based on the skin page it's on?
This is the approach I had in mind. Also, inh mentioned above that RR uses keyTBL and execTBL to allow context switching. So for RR, it looks like just pumping out some key presses from the driver may allow this to integrate with RR
Another way is to write a file somewhere, which tells the current context. This would allow many apps to get that info, but for FE's, this would require additional code.
I guess the ultimate way of making this work, is to request integration from FE writers.
exactly, and pulse mode allows you to tweak how often to pulse by providing parameters for a range (start pulse rate and end pulse rate) and how to accelerate through that range (linear or exponential)
agreed. I think starting with one mechanism, then changing as required is the best way to go.
Current:
Previous:
cool, sounds good to me.
The text overlay is an idea, it would have to fade away or go away and not be persistent though. Maybe a gesture that shows you what context you are in?
No RR keeps the same window title, but the only time you would need to change the context for RR to something different would be when you have an embedded application running, like GPS or the webbrowser. I really cant think of anything else you would really need to have a different set of commands.
RR is pretty easy to control as far as keyboard goes, LEFT, RIGHT, UP, DOWN and ENTER will navigate the whole app. I dont think in practice you with need to have different context on different standard screens in RR as they all can be controlled with those 5 keys. Only embedded apps would need a different context. If the driver app would accept commands from RR to switch the context everything would be golden on RoadRunner side of things.
Yup, pretty much thats all thats needed and the ability to run an application with command line options.
I think all the top 3 FE's, RR, CF and SD (is there really anything else on the same level) all have some sort of keyboard control for all its functions. So i dont think this would even be necessary.
will there be a mouse mode?
mp3car live search
