Sony Ericcson AT codes over BT
AT*EALR=3,1,2
I am trying to listen to a call on my bt dongle from a 700i. I get the accepted result but am now stuck as to how to listen to the call via the pc.
Anyone any ideas?
Marc
You have to connect the audio gateway. If you are using the standard bluetooth drivers that come with windows those will not work. You'll need the widcomm drivers. As well unless your phone supports concurrent serial and audio connections you will need to disconnect the serial connection first.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
