Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: never lose focus
  1. #21
    Aug 1999
    Upper Marlboro, MD 20772
    just for the hell of it here is another thing u can use too... diff but will work too
    Declare Function SetFocus Lib "user32" Alias "SetFocus" (ByVal hwnd As Long) As Long
    Identifies the window that will receive the keyboard input. If this parameter is NULL, keystrokes are ignored.
    And here is the example
    Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As Long, ByVal lpWindowName As Long) As Long
    Private Declare Function GetParent Lib "user32" (ByVal hwnd As Long) As Long
    Private Declare Function SetParent Lib "user32" (ByVal hWndChild As Long, ByVal hWndNewParent As Long) As Long
    Private Declare Function GetWindowThreadProcessId Lib "user32" (ByVal hwnd As Long, lpdwProcessId As Long) As Long
    Private Declare Function GetWindow Lib "user32" (ByVal hwnd As Long, ByVal wCmd As Long) As Long
    Private Declare Function LockWindowUpdate Lib "user32" (ByVal hwndLock As Long) As Long
    Private Declare Function GetDesktopWindow Lib "user32" () As Long
    Private Declare Function DestroyWindow Lib "user32" (ByVal hwnd As Long) As Long
    Private Declare Function TerminateProcess Lib "kernel32" (ByVal hProcess As Long, ByVal uExitCode As Long) As Long
    Private Declare Function GetCurrentProcess Lib "kernel32" () As Long
    Private Declare Function Putfocus Lib "user32" Alias "SetFocus" (ByVal hwnd As Long) As Long
    Const GW_HWNDNEXT = 2
    Dim mWnd As Long
    Function InstanceToWnd(ByVal target_pid As Long) As Long
    Dim test_hwnd As Long, test_pid As Long, test_thread_id As Long
    'Find the first window
    test_hwnd = FindWindow(ByVal 0&, ByVal 0&)
    Do While test_hwnd <> 0
    'Check if the window isn't a child
    If GetParent(test_hwnd) = 0 Then
    'Get the window's thread
    test_thread_id = GetWindowThreadProcessId(test_hwnd, test_pid)
    If test_pid = target_pid Then
    InstanceToWnd = test_hwnd
    Exit Do
    End If
    End If
    'retrieve the next window
    test_hwnd = GetWindow(test_hwnd, GW_HWNDNEXT)
    Loop
    End Function
    Private Sub Form_Load()
    'KPD-Team 1999
    'URL: http://www.allapi.net/
    'E-Mail: KPDTeam@Allapi.net
    Dim Pid As Long
    'Lock the window update
    LockWindowUpdate GetDesktopWindow
    'Execute notepad.Exe
    Pid = Shell("c:\windows\notepad.exe", vbNormalFocus)
    If Pid = 0 Then MsgBox "Error starting the app"
    'retrieve the handle of the window
    mWnd = InstanceToWnd(Pid)
    'Set the notepad's parent
    SetParent mWnd, Me.hwnd
    'Put the focus on notepad
    Putfocus mWnd
    'Unlock windowupdate
    LockWindowUpdate False
    End Sub
    Private Sub Form_Unload(Cancel As Integer)
    'Unload notepad
    DestroyWindow mWnd
    'End this program
    TerminateProcess GetCurrentProcess, 0
    End Sub
    abcd-1
  2. #22
    Aug 1999
    ok the last one from me
    http://www.allapi.net/tips/tips.shtml
    abcd-1
