Results 1 to 5 of 5
Thread: How safe is EWF?
    Maximum Bitrate Maņana's Avatar
    Jul 2004
    Sweden
    How safe is EWF?
    Exactly what the title says... F.ex, is there any reason to install an antivirus program? Firewall? Of course the computer can still be hacked and so on, but it will not hold any personal information, so thats not an issue...
    FLAC SFiorito's Avatar
    May 2004
    EWF is not an antivirus solution. Sure, it will prevent any writes to the disk, but it will not block boot sector viruses. However, if a virus is in the disk overlay and you commit it, then the virus is now physically written to disk.
    If the system is disconnected and you don't download random programs from the web then you'd probably be safe enough.
    Jul 2004
    Sweden
    It will connected to the internet, but only to sync google calendar info (i know i said it wouldent contain personal info, but i dont mind people reading that )
    Having an antivirus will, as far as i understand, be quite a problem with ewf since it needs to update its virus database!?
    May 2004
    yes, that's correct. if you plan on having this system on for long periods of time without a reboot then you may run into out of memory errors due to antivirus updates filling up the EWF disk overlay. I think you'd probably be fine without antivirus as long as you had a firewall on it and were careful with what you downloaded/installed to it.
    Jul 2004
    Sweden
    Then I guess I'll go without it =) Mybe make a ghost image of the drive when everything is set, so I can just use that if things get messy.
  1. Safe nLite setting.ini
    By IntellaWorks in forum WinNT Based
    Last Post: 02-03-2010, 06:41 AM
  2. Using EWF on regular WinXP
    By SFiorito in forum WinNT Based
    Last Post: 03-17-2009, 07:43 PM
  3. Replies: 12
    Last Post: 03-16-2009, 08:00 PM
  4. Minlogon, EWF and HORM - Problem Fuzzy screen menus after HORM hibernate
    By ruairi in forum Operating System Optimization
    Last Post: 11-30-2005, 08:51 AM
  5. how to get rid of safe mode in WinMe
    By moahdib in forum Software & Software Development
    Last Post: 12-13-2001, 04:58 AM
