just a small request. I found that in the xmls you can set the default resolution of the mediate, how about also a default position? Just offset from the topright most pixel, or something like that =)
Beta release now available: mediate ICE - http://www.mediateice.com
@home media limited
http://www.athomemedia.co.uk
1. At some point we'll include this functionality in the main theme, but its fairly low priority at present since it typically only gets done once then ignored. Ideally, everything should be touch screen friendly but it takes a lot longer to implement compared to using Windows forms.
2. That feature has already been requested and we're working on implementing that for the next release. Soon hopefully!
3. The skin/theme is a work in progress.. really we would love some community input as there is a lot of talent out there, but realistically we would have to release the theme designer first.
@home media limited
Thanks for reporting that. We haven't tested mediate on Vista yet, although there are reports of it working fine from our users (this issue aside). We now have a Vista test machine so will take a look at these points.
@home media limited
I personally am not a designer but i know from my own personal experiance is
that if i liked the screen shots of the app then i would try it and then look at the functionallity.
my first choice a couple yrs ago when i started was frodoplayer because of the sony skin design it was really nice. they i tried mobile impact but i left it because of the lack of functions. now i am currently using Centrafuse and it is really good all around but it will not be free soon.
hopefully that helps
Well, close to. I suppose you know about the problem with getting the integrated graphics on epia mobos to output 800x480 to 7" widescreen displays?
I found a workaround. If I make my mobo output 800x600, I can then (with some bios settings) make the screen think its 800x400 in a way that it cuts the top eight and botton 112 pixels so that it displays 800x480. That gives a clear image with mapped pixels, and it works very well as long as I'm possible to force the frontend to just use those 800x480 pixels.
Hi, I am newbie and was looking for a frontend for my car. I am using UMPC Samsung Q1 with pentium processor. I bought it so it can be mounted in my Fj. I am hoping you will finalize this frontend with Iguidance 3.0 as soon as possible.
Thanks again for the effort.
Will this work with Xp tablet?
thanks.
Currently using Roadrunner...but checked mediate ice... this is a bad *** front end.... I LOVE it...but would love it more if it pointed to a gps location
I installed it on my umpc and for the most part it work ok. the only problem is that i am unable to change the color from the setup menu. it just doesnt select any color. i installed and reinstalled several time without any change. Please help.
thanks
