Results 1 to 6 of 6
Thread: Using XMD Direct on a PC
    May 2009
    I have an XM Direct unit from my car (2003 M3 that got totaled). While I look for another car I am trying to get the XM Direct working with my PC.
    I have researched this and found many older references to XM XCR, XtreMePCR etc. and I made a serial cable.
    Can anyone advise on the best SW to run an XM Direct from a PC and where to find it.
    Cheers
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Riderunner and Centrafuse both support the XMDirect box. I have one and use both. Look in the software section under frontends to find links to downloads.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    May 2009
    Thank You
    Quote Originally Posted by fixerofallthing View Post
    Thanks, I'll take a look in that section.
    Low Bitrate IssaquahWA1979's Avatar
    Oct 2009
    Issaquah Washington
    did you ever get this working?
    Custom Built Intel D510MO, 2GB RAM, M4-ATX, Elios 15" TS on custom mount.
    System installed into 2005 Dodge Ram 3500 Cummins Diesel 4x4.
    I can provide Custom fabrication for mounts or installation please contact me. CNC Machining and Powder Coating
    Feb 2006
    Dallas
    Has anyone converted the XM VB6 code, (say from Roadrunner) to VB.net? I would like to convert my own frontend which was in Delphi to VB.net and this is proving to be a long tideous job. Biggest hassle is the serial port stuff. VB6 used mscomm, vb.net needs a lot of help from what I can tell.
    Thanks, Walt
    MySQL Error
    Oct 2004
    Satamp
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
