Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: How to make your bt878 or other radio/tv tuner work with Radiator
  1. #21
    Jan 2004
    NYC
    Quote Originally Posted by Skraggy_uk
    This is fantastic. After removing the original Hauppage drivers, and installing those, fantastic, my copy of Radiator now works, without the XP issue that the Radiator message boards mention.
    what hauppage card are you using, please tell me this would work with the hauppage Wintv FM USB
  2. #22
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    It's a WinTV PVR/FM PCI card. Don't know if Radiator or the BTWincap drivers support the USB WinTV units as I've never owned one, Sorry.
    4x4 in a turbo stylee.
  3. #23
    Jan 2004
    NYC
    thanks for the info - so you can now use frodo, centrafuse built in radio functions?
    n8scstm - what are chances of this working with a USB wintv unit, im trying to find some info that states what chip these things use with no luck
    i would try it out but I have the USB configured nicely in my car already, its such a pain in the *** to configure/test something on the carPC
  4. #24
    May 2002
    Warrington UK
    Yep,when testing on my main PC, I get radio function at least in Centrafuse (haven't tried Frodoradio part. Can't see why it don't work though if it uses Radiator.
    going to be physically building the car PC soon, once I get my Nlited custom install disk sorted.
  5. #25
    Illinois
    man, i can get sound, but its stuck on the station it was last tuned too. I tried your, TV CAN TUNE RADIO, but it still doesnt work.
    When windows is installing the new drivers, everythiung seems to work except for the TV tuner, which I get the, "this device can not start (code 10)" error.
  6. #26
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    anyone have luck with getting the aimslab vhx card to work with this? so far i can get it to tune TV fine, but FM is a no go. and unless im mistaken, there are no xp compatible drivers so im stuck with just the generic bt8x8 drivers.
    Your everyday carpc geek and tech guru at your service. *bow*
  7. #27
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Quote Originally Posted by nappyjim
    I had this problem too. Uninstall everything. I mean everything. Go into the hardware manager, click view, show hidden devices, non-plug and play devices, and search for anything related to the card. Then try to reinstall it only using the custom btwincap drivers. It should only ask for 2 drivers. If it asks for more, dont install them, and go back into the hardware manager and disable the ones that have the question mark next to them. Then try radiator again. Good luck.
    And I have no idea about the usb model.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  8. #28
    Jan 2005
    Warren, Ohio, USA
    damn. im also getting the same problem (device cannot start code 10). unfortunately, other than previously installed devices like the sound card, audio/video codecs, etc.. i cant find anything related to the tuner. i both went through the bt driver installer and just the device manager to remove it, but nothing has worked. i also found a driver on driverguide.com which had the same bt driver installer, but included an aimslab vhx btspy report which i used, but i still cant get anywhere with this
  9. #29
    Oct 2004
    Have you made your own spy report?
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  10. #30
    Jun 2003
    Memphis - TN
    I formatted, and onlyinstalled the BTwincap drivers, Mines a no go, screw it.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  1. What do I need to make this work?
    By SavageKabbage in forum LCD/Display
    Last Post: 03-13-2004, 01:48 PM
  2. What do I need to make this LCD work with compoosite video?
    By pigseye in forum General Hardware Discussion
    Last Post: 02-19-2002, 08:36 PM
  3. Replies: 2
    Last Post: 10-07-2001, 11:43 AM
  4. Whats requried to make the EIO.com 5" display work
    By Squeezer in forum General Hardware Discussion
    Last Post: 07-15-2000, 02:20 PM
  5. Can you make a portable TV work?
    By type2guy in forum General Hardware Discussion
    Last Post: 08-23-1999, 10:39 PM
