Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: How to make your bt878 or other radio/tv tuner work with Radiator
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    I have an extremerly generic bt878 card and this worked for me. I'm sure it will work for most cards. First step is to download btwdmdrvinstaller5.3.8.zip
    from http://btwincap.sourceforge.net/download.html. This is an .exe that will run and allow you to choose your card from a list then install the drivers for that card. If your card is odd like mine it wont be in the list. If it isnt, download btspy from that same site. Install your original drivers and software, then run btspy and follow all the directions. It will create a .txt
    Then run btwdmdrvinstaller again. This time for card, choose custom. The next page will allow you to import the .txt. Then install the drivers and install radiator. All should be working. You may need to mess with some of the radiator settings, but I didn't need to. Here is some more info on btspy.
    http://btwincap.sourceforge.net/custom.html
    good luck!
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Jun 2003
    Memphis - TN
    Tried that already no go
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Oct 2004
    We have the same card though. Ill pm you my spy report. Compare it to yours. Ill make a screenshot of my radiator settings too. I'll post as soon as I get home.
    For now try this. Uninstall all drivers. Reinstall your original drivers. Make sure they work with your original software. Run btspy again. Run the .exe to install the new drivers. When this happens, windows will say, "found new hardware." Click cancel. It will ask again. Click cancel again. Restart your computer. It will say found new hardware again. Cancel twice, just as before. Then go into hardware manager and disable the 2 items that have the yellow question marks. I'll make a screen shot of this as well. Try this and let me know. Good luck.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Jun 2003
    Memphis - TN
    http://s88024846.onlinehome.us/tv/
    my BT spy report is on there.
    Jun 2003
    Memphis - TN
    Does your chip say BT878a?
    Conexant Fusion?
    Oct 2004
    I saw yours but I'm at work so I dont have access to mine at the moment. Pluse we know that mine works. So you can try to create the drivers using my profile. Post a pic of your hardware manager with the sounds column expanded. I'll see if it looks like mine.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Oct 2004
    Here is the screen shot of radiator settings.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Oct 2004
    Hardaware manager. The 2 with the question marks i had to disable to prevent windows from trying to install new drivers everytime i turned on the computer.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Oct 2004
    and card profile. This is the profile for the SuperTv tuner. It most likely will not work with others so dont try, unless thats the card you have.
    Attached Files Attached Files
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    This is fantastic. After removing the original Hauppage drivers, and installing those, fantastic, my copy of Radiator now works, without the XP issue that the Radiator message boards mention.
    4x4 in a turbo stylee.
  1. What do I need to make this work?
    By SavageKabbage in forum LCD/Display
    Last Post: 03-13-2004, 01:48 PM
  2. What do I need to make this LCD work with compoosite video?
    By pigseye in forum General Hardware Discussion
    Last Post: 02-19-2002, 08:36 PM
  3. Replies: 2
    Last Post: 10-07-2001, 11:43 AM
  4. Whats requried to make the EIO.com 5" display work
    By Squeezer in forum General Hardware Discussion
    Last Post: 07-15-2000, 02:20 PM
  5. Can you make a portable TV work?
    By type2guy in forum General Hardware Discussion
    Last Post: 08-23-1999, 10:39 PM
