Think this is relatede to Mappoint 2006 data. I get similar issues with the europe version of SD, it can be temporarily resolved by toggling the virtual earth on and off.
(HTH)
What version of StreetDeck is this bug report for?
1063
Please give a basic description of the issue here.
navigation zoon vertical lines
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
when zooming every other level has vertical lines and the map is completely unreadable.
1990 Jeep Cherokee
2000 VW Golf TDI 4dr
2005 VW GTI MKIV - SOLD
(HTH)
Any updates on this in the new release? Still having these problems?
Jan Bennett
I certainly am still having display issues with the nav and i feel these vertical lines are related to my loss of all map imagery in 1.0.8.1.
An update on how things are going would be good
please retest on 1.0.9.8 and report back with your findings.
Jan Bennett
Please retest on 1.0.9.8 and report back with your findings.
Jan Bennett
I have retested with 1.0.9.8 and oweing to the fact that my nav projection isnt fixed I guess this issue is still present as well
Chuck/Adam - updates?
Jan Bennett
I have done some research on the graphics cards both of you are using. This seems to be an issue with map point and a SIS graphics cards you are using. The jetway J7F3 and the Mirage are using this same SIS processing. You could check for the latest driver updates and see if that fixes the issue.
I am running the latest drivers downloaded direct from SIS.
