No sound in Video module
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
When I enter the Video module and play a DVD disc, there is no sound. I click "volume" on the upper right corner and go to settings. I notice the "play media" volume bar is zero. I raise the volume and there is sound. However, when I click the mini video screen on the lower left hand corner, full screen of video pops up but the sound is back to zero again.
I repeat going into volume setting and notice that "play media" volume bar is zero again. I raise it and I can hear sound again. If I press the back arrow at the top, the sound is maintained. When I hit the mini screen to maximize the video, the sound goes blank.
Also, whenever the DVD or the Video module starts, the "play media" volume goes down to zero.
I've had this problem with version 1.0.6.3. I just installed Infill T3/SD few days ago. After update 1.0.8.1 the problem continues.
please retest on 1.0.9.8 and report back with your findings.
I'm sorry but I can't report back to you regarding "No sound in Video module" issue in my T3, as I'm not running StreetDeck in my T3 right now.
Maybe someone else who had this issue can say something after the update.
Toggle Streetdeck check the settings in the windows sound control panel when playing the video.
since the OP is no longer using StreetDeck, this bug report has been closed.
