Results 1 to 8 of 8
Thread: TV module not working
    Feb 2007
    CA
    What version of StreetDeck is this bug report for?
    1.0.8.1
    Please give a basic description of the issue here.
    Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    yes
    If no, please describe your system here.
    Please provide any relevent information regarding the issue you have encountered.
    TV stopped working after the 1.0.8.1 update. I think the problem is with the latest update as it worked perfectly before the update. The Music and Radio modules work fine. It seems like when I press the TV button the module doesn't even initialize. The same page just refreshes. Maybe there's an error where there is no command to start the TV module when the button is pressed.
    Infill T3 with Infill Station
    2007 Hyundai Sonata
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    The TV hardware is not started when launching the module because of how modules are launched in the new update. If you start TV by binding the TV function to a gesture or something else, it should work now.
    This will be fixed in the next update.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Feb 2007
    CA
    Quote Originally Posted by god_of_cpu View Post
    Thank you. I used the gesture for TV, and voila, the TV module is back alive. I was little scared when the TV didn't work, because I spent alot of time installing the TV antenna on my rear window. It's my first time with a TV in a car but the picture quality is quite good with the powered antenna.
    2007 Hyundai Sonata
    Constant Bitrate sharpmat007's Avatar
    Nov 2006
    Washington, DC
    Same issue and solution works. Chuck, hit me up if you need me to test the update prior to release.
    Mitsubishi Eclipse 2006 GT
    Infill T3 running StreetDeck
    Newbie rburhum's Avatar
    Mar 2007
    SoCal, USA
    Does that mean that if I unbind the gestures for navigation that SD won't try to initialize go trough the autodetection sequence of my GPS receiver and get a hold of it?
    _
    Mar 2004
    Little Elm, Texas
    please retest on 1.0.9.8 and report back with your findings.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Thread closed due to a lack of follow-up from the original poster. 8 days have passed without a response.
    If the original poster would like to have this thread back opened, he/she may do so by going to the 'Thread Tools' drop down box at the top of the thread. If the Original Poster does so, the Original Poster must post information in response to requests for additional testing. Else, the bug report will be closed again.
    Jan Bennett
