Here's the log -- at least what it got before the BSOD.
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
System Blue screens right after Streetdeck starts
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
Installed new 1.0.8.1 update and Streetdeck stopped working right.
uninstalled and reinstalled -- same deal.
Get BSOD with
PAGE_FAULT_IN_NONPAGED_AREA
igxpdx32.dll is the offending driver (graphics)
STOP 0x00...050
Intel 945gm chipset, driver version 6.14.10.4785 (latest available on their site)
I noticed as the program started to load that there were 2 lines or so of the taskbar showing at the bottom of the screen -- this is also new to this revision.
Prior to the reinstall I was able to get into SD, it loaded right into NAV module and appeared to work but if you try to navigate out of the NAV module the screen you were going to shows up for a sec, slightly distorted background (behind buttons), and then BSOD. Same BSOD everytime.
I'm rendered useless now.
I had the same problem with the latest i945 drivers.
Kalt - is that to assume that reverting back to the older driver fixed the issue?
Jan Bennett
i had this problem. is service pack two installed?
Engineering....Where the unknowing teach the unwilling the unnecessary.
please retest on 1.0.9.8 and report back with your findings.
Jan Bennett
Jan Bennett
Thread closed due to a lack of follow-up from the original poster. 8 days have passed without a response.
If the original poster would like to have this thread back opened, he/she may do so by going to the 'Thread Tools' drop down box at the top of the thread. If the Original Poster does so, the Original Poster must post information in response to requests for additional testing. Else, the bug report will be closed again.
Jan Bennett
