Results 1 to 10 of 11
Thread: Music Queue Clears after shut down
    Jun 2006
    Ventura County
    What version of StreetDeck is this bug report for?
    1.0.8.1
    Please give a basic description of the issue here.
    Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    yes
    If no, please describe your system here.
    Please provide any relevent information regarding the issue you have encountered.
    I selected "Play All Songs" which added all of my songs to the queue. After shutting down and restarting the entire queue is cleared out except for the song that was playing prior to shutting down. This happends consistantly after shutting down and starting back up.
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    Second. And, when I do 'stand by' (which is the default shutdown action) and then get back in the car and resume, my queue is doubled (i.e. if I had 15 songs in the playlist when sutting down, I now have 30 - - the same 15 repeated in sequence).
    Feb 2007
    Arlington, VA
    I see the same issue in 1.0.8.1.
    Feb 2007
    CA
    SD doesn't remember the list.
    I have the same problem. SD doesn't remember the music list. It thinks there are no music in the computer even after the list had been created previously. My shut down setting is on "Stand-by."
    Infill T3 with Infill Station
    2007 Hyundai Sonata
    StreetDeck Staff
    Jun 2006
    Columbia, MD.
    For those of you who have issues with the playlist not resuming, please make sure you have the following file... The file is called StreetDeck.WPL and is responsible for storing the music in the queue. The file should be located in My Documents-->StreetDeck. This should fix the problem...MP
    Attached Files Attached Files
    Jan 2004
    Seattle, WA
    i have that file already and still experience the problem. (I did not replace that file with the one you posted here, though...should I?)
    Jun 2006
    Ventura County
    yeah, the more I use it, the more I realize that there is something else going on... The playlist doesn't always clear out, sometimes it plays the song I was listening to as well as a second or even a third song that was in the previous playlist before restarting
    Newbie onidragon's Avatar
    Aug 2006
    Chico, CA
    yeah i have the same problem, after SD starts again i have only four songs in the queue. Two are always the same and two vary. Always starts with the same song and i swear if i have to start with Weird Al's "taco grande" one more time......
    _
    Mar 2004
    Little Elm, Texas
    please retest on 1.0.9.8 and report back with your findings.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
  1. Music Playing Over GPS Voice Prompts
    By Jay95 in forum Centrafuse
    Last Post: 12-01-2006, 11:14 PM
  2. Problems going from XM to Music
    By Damon in forum StreetDeck
    Last Post: 11-19-2006, 02:16 AM
  3. Play Music Files among Several Computers
    By Wiredwrx in forum Off Topic
    Last Post: 08-08-2005, 10:49 PM
  4. Ok. I start music, and flick to the home screen.
    By Skraggy_uk in forum ME Archive
    Last Post: 08-26-2003, 06:01 PM
  5. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 10:08 PM
