Volume keyboard control go above expected range
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
I have a F4-F5 mapped to SD volume up/down. I have another app send those keystrokes to SD window when a corresponding button is pressed. Almost always when I have the volume around 50 and then generate a bunch of Vol+ keypresses SD will increase the volume to 100, as expected but after that will continiue to increase the volume to, what appears to be, 255. Once you go above 100, my vol+ vol- keys don't work and I have to use the mouse/touchscreen to get the slider back into legitimate range.
When scrolling with mouse i could set the volume over 100
1.0.8.1
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
No
ASUS P4P800
Intel Northwood 3.0Ghz
XFX Nvidia 6600Gt
2Gb RAM
Creative X-Fi
Not CarPC but normal desktop PC.
Managed to get to 270 or something)
- Only in 1.0.8. This didn't happen in 1.0.6.
