Mine acts like that too. I also noticed, if I look closely SD is off to the left by a few pixels. I can see the desktop behind it.
It seems like its not actually running as a full screen app anymore.
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
Windows taskbar and notification bubbles show up on top of streetdeck interface
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
Since upgrading I have noticed that when streetdeck launches, I see several windows yellow bubbles in the right corner.. things like "wireless networks detected", "updates are available", etc. These bubbles "flash" at what appears to be the same rate as the frames per second direct x refresh rate.
I have my taskbar set to auto-hide, but if I turn that off I see the status bar as well.
Another user has reported this same issue in the forums.
I had that problem too but when i updated to the 1.8.1 version it was fixed. hope that helps.
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
Any Updates? Have you been able to reproduce this bug?
No, we haven't been able to duplicate this issue yet.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
I had the exact same problem but reinstalling SD fixed it for me! I did a clean install.![]()
If I understand your problem here, there's a problem when the bubble tips of windows "pops" it apears on top of ur apps.
If you want to remove or disable the "Bubbletips" in windows you simply have to add a registrykey in your REG KEYs.
Here's the step by step...
1.Click on Start and then on Run.
2.In the open box type regedit and then click OK.
3.Click on the plus (+) next to HKEY_CURRENT_USER.
4.Click on the plus (+) next to Software.
5.Click on the plus (+) next to Microsoft.
6.Click on the plus (+) next to Windows.
7.Click on the plus (+) next to CurrentVersion.
8.Click on the plus (+) next to Explorer.
9.Click on the folder Advanced. This should give you a long list of items on the right window pane.
10.Click on Edit, select New, and choose DWORD Value.
11.Name the new DWORD Value EnableBalloonTips.
12.Double-click this new entry, set the value to 0.
13.Fill in the dot next to Hexadecimal.
14.Close the Registry Editor and reboot the computer normally.
You have now disabled the balloon tips in the system tray.
I hope this helped some one since so many people had the same error.
VMTSQUAD
And for those of you scared (or too lazy) to go into the registry, grab Tweak UI from Microsoft to disable balloon tips (under taskbar and start menu).
I don't have any experience with SD, but you may want to disable applications from stealing focus (general > focus).
