Results 1 to 10 of 17
Thread: Buffer overrun when indexing music - 1.1.0.0
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    What version of StreetDeck is this bug report for?
    1.0.8.1 - 1.1.0.0
    Please give a basic description of the issue here.
    Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    yes
    If no, please describe your system here.
    Please provide any relevent information regarding the issue you have encountered.
    This may have been an issue in the 1.0.6.3 release also. If I tell it to index, it will start, but then I get a C++ run time error within seconds stating that SD caused a buffer overrun and in order to maintain a stable system, the application will now be terminated. I've attached a -verbose log, but the gist of it seems an access denied as follows:
    INFO: CSyncController::SetStatusString - Indexing files...
    WARNING: .\SyncController.cpp:586 HRCALL Failed!
    0x80004005 = m_lpmngAudio->AddMediaToCollection(strFileName, &pMedia)
    Attached Files Attached Files
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Until this bug is fixed, you can index all your media files in windows media player and they will show up in StreetDeck.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Jan 2004
    Seattle, WA
    sorry to be naive here, but how exactly do i do this? Artist/album has shown up in SD 1.0.8.1 in the past, but as of yesterday it doesn't anymore, and as stated, I believe it to be related to this indexing error. How do I rebuild the WMP index so SD will display it again?
    Jan 2004
    Seattle, WA
    FYI - I figured out how to delete the WMP database, and then let it rebuild. This made my 'artist', 'album' entries show up again. Now, when I tell SD to reindex, it will cause a different c++ error (I will get this info to you later). If I click 'OK' on the error, it will terminate SD. If I don't, SD will continue to index.
    EDIT: the buffer overrun is the error that is reported. Clicking OK on the Windows error dialog box closes SD.
    _
    Mar 2004
    Little Elm, Texas
    please retest on 1.0.9.8 and report back with your findings.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Thread closed due to a lack of follow-up from the original poster. 8 days have passed without a response.
    If the original poster would like to have this thread back opened, he/she may do so by going to the 'Thread Tools' drop down box at the top of the thread. If the Original Poster does so, the Original Poster must post information in response to requests for additional testing. Else, the bug report will be closed again.
    Jan Bennett
    Jan 2004
    Seattle, WA
    just saw that I was slacking on reporting back..sorry
    This is still an issue in the current build.
    Thanks,
    Per
    _
    Mar 2004
    Little Elm, Texas
    Can you post your most recent log?
    Jan Bennett
    Jan 2004
    Seattle, WA
    I'll get the log off later, but I'm pretty sure I have it figured out. I just went into SD and told it to re-index. I chose 'Yes' when it asked me if I wanted to clear the existing index so as not to have duplicate entries.
    It cleared out the index and then started re-indexing in reverse alphabetical order (i.e. Z to A). It chocked all the way at the end with the artist "...And They Will Know Us by The Trail of Dead" (nice name, eh? ..go indie rock ). I'll put some money on the fact that the "..." - which is part of their name - is what's causing problems. As I have WMP rename all files with artist name included, this "..." is in the file names also.
    WMP doesn't have issues, SD does. Chuck - guessing the 3 periods are the culprit?
    -Per
  1. Music Indexing
    By aforget in forum StreetDeck
    Last Post: 02-06-2007, 10:25 AM
  2. Music Age/Organization
    By Quattro in forum Software & Software Development
    Last Post: 01-24-2006, 06:12 AM
  3. No auto resume music and video?
    By organasised in forum Road Runner
    Last Post: 02-10-2005, 09:55 PM
  4. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 09:08 PM
