Results 1 to 9 of 9
Thread: Can not delete music from flash drive
    Jan 2007
    What version of StreetDeck is this bug report for?
    1.0.8.1
    Please give a basic description of the issue here.
    Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    yes
    If no, please describe your system here.
    Please provide any relevent information regarding the issue you have encountered.
    Sorry for posting more than once, but no one responded to my earlier post about this issue so I thought I would just post it as a bug report and see if I get any answers.
    When playing music from my flash drive, deleting music removes it from the playlist but not from the flash. When I replay the folder from the flash drive, the music file reappears. I have set the option to remove files from the drive when delete music is selected.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    THis is due to the fact the delete function fails to remove the item in the music collection since its not in teh collection and just a file on the flash drive.
    It should be fixed in 1.0.8.5
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Jan 2007
    OK. Thanks for the feedback.
    _
    Mar 2004
    Little Elm, Texas
    please retest on 1.0.9.8 and report back with your findings.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
    Jan 2007
    The delete feature seems to work on the flash drive now. However I noticed that if I go back in the menu to list the files in the last folder I was in, I still see the file I deleted, even though I can't play it. I would have to go back to the parent folder and reselect the folder containing the files I was playing before the list is accurate (not showing the deleted files).
    _
    Mar 2004
    Little Elm, Texas
    knyarko - this does seem to be a bug.
    I will pass this along to the QA and development team.
    Jan Bennett
    Jan 2004
    Quote Originally Posted by knyarko View Post
    This is by design. File enumeration can take a significant amount of time particularly on removable media if there are alot of files on the drive and is only done when entering the module not going back to it. At this point it is a known limitation, but may be improved in future versions.
    _
    Mar 2004
    Little Elm, Texas
    Good to know Chuck.
    I'm closing this bug report then since the initial bug has been resolved.
    Jan Bennett
  1. Replies: 4
    Last Post: 12-04-2008, 02:29 PM
  2. Slim dvd drive problems. JAE 50pin to IDE at fault?
    By 2k1Toaster in forum General Hardware Discussion
    Last Post: 08-16-2007, 05:06 PM
  3. Samsung 16GB flash drive
    By hanzacra in forum General Hardware Discussion
    Last Post: 05-25-2005, 04:24 PM
  4. FS: 800mb IDE Flash Drive SimpleTech
    By Tidder in forum Classified Archive
    Last Post: 11-27-2004, 09:52 AM
  5. Flash hard drive on ebay
    By Mp3 V in forum General Hardware Discussion
    Last Post: 02-16-2002, 12:39 PM
